72 new tko, hydraulic or mechanical clutch with long tube headers?
Discussion in 'Transmission & Driveline Topics' started by biggrass, Aug 23, 2019.
  1. czizza
    czizza Veteran Member
    1,004
    52
    Jan 8, 2004
    N. Massapequa, NY, USA
    I have a small block, Hedman headers and a manual clutch setup with my TKO. I have used a 621 Bell and I now have the quicktime both super easy and compatible.
  2. biker
    biker Veteran Member
    808
    60
    Dec 7, 2014
    New Liskeard Ontario Canada
    I'm with you on that. If you can recommend a good one, I will research and consider it. Would love to have less linkage and wear points.
  3. C4Racer
    C4Racer Veteran Member
    641
    109
    Oct 26, 2018
    with aftermarket it's not really a purely bolt-in "system" per-se. You put it together yourself essentially. Start with the bracket and built it from there. I used the Tilton 6000 series bearing which works great. The bracket set-up I am using mounts 3 masters where the stock brake master goes - two for the brakes and one for the clutch. But if I was running stock brakes I would just pick up a bracket from DSE or speedtech or whoever makes one for a stock pedal 2nd gen set-up. Then you pick your master to match the bearing you are using and set-up the linkage accordingly. Linkage is not hard - standard rod end pushrod type set-up which is completely adjustable for pedal location. Then you build a clutch stop per the recommendations of the bearing mfg. It's actually very simple once you get into it.
