72 SS Hurst shifter
Discussion in 'Original Drivetrain Topic' started by kamaro kid, Sep 9, 2018.
  1. kamaro kid
    kamaro kid New Member
    26
    Oct 24, 2017
    North Cacalacki
    Reposting a transmission forum question here since it's resto related. Have a 72 SS396 with Muncie, trying to identify correct shift lever for the GM over-the-counter Hurst shifter, I've seen one with Hurst letters above the bend area and one with letters in the bend area as imaged below. Anybody know what is correct?
  2. greeny
    greeny Veteran Member
    221
    17
    Feb 21, 2005
    arizona
    Your 72 did not come with a Hurst shifter, it came with an ITM. If you do a search in this section your should find a lot of quality information.
  3. greeny
    221
    17
    Feb 21, 2005
    arizona
  4. dave@ztech
    3,512
    720
    Mar 27, 2016
    NY
    And the reason you may have a Hurst shifter, is the factory ones were crappy and lots of people changed them to a better, tighter shifter
  5. kamaro kid
    26
    Oct 24, 2017
    North Cacalacki
    Thanks for your replies. I have been told by 2 sources that GM Parts sold a Hurst shifter in 72 with same lever features as the ITM and with Hurst name on lever. Ever heard of that? It MAY have been a carry over from previous year.
  6. dave@ztech
    3,512
    720
    Mar 27, 2016
    NY
    To respond to the original question, the Hurst name would be in the top section , above the bend , if I understood the question. HAA HA , and it's possible that I did't .
  7. twozs
    twozs Veteran Member
    8,817
    168
    Aug 5, 1999
    hopewell jct ny
    Trans am went on to use the Hurst for a few more years and I do believe they work in a Camaro . An ITM shifter wouldn’t have a Hurst handle as far as I know .
  8. kamaro kid
    26
    Oct 24, 2017
    North Cacalacki
    Thanks to all for the info.
  9. Gary S
    22,661
    835
    Correct. The Trans Am used the Hurst shifter into the late 70s or possibly even the early 80s. The ITM shifter was a complete ITM unit so it wouldn't have a Hurst handle. The Hurst shifter was likewise a complete unit with its own shifter. Also, Hurst offered their own version of their shifter for people who tired of fighting with the ITM shifter that never worked as well. Many of the ITM shifters were replaced by the car owners, just as most of the early Muncie shifters in Camaros, Chevelles, and Impalas were replaced by Hurst shifters directly from Hurst.
  10. Budz
    3,113
    123
    Mar 17, 2002
    Ashburn, Va USA
    I'm not up on '72 model's, but here's some old info from our former mystery expert M21RSZ28 showing a Hurst Shifter handle for ALL '72 4Spd Camaro's, with or w/out console's
