73 Base Camaro going to 2006 LS2 4L65E
Discussion in 'High Tech Retrofits' started by mrfleet12, Aug 20, 2017.
  1. 71RSLS
    71RSLS Veteran Member
    725
    150
    Dec 5, 2017
    Prairie City, Ia
    Very nice 73, and nice work on the LS swap. The bottom of your floor looks mint too!
  2. mrfleet12
    mrfleet12 Veteran Member
    241
    34
    Aug 8, 2014
    West of Chicago IL
    Thanks, buying them from AZ helps.
  3. mrfleet12
    241
    34
    Aug 8, 2014
    West of Chicago IL
    Hello
    Haven't updated in a while, been making progress but haven't had time to sit down at the computer..
    Got everything wired and plumbed just to fire the car and check the engine and trans since it was a used setup. Running the Fitech 70051 kit to manage the engine and trans, I opted to use my LS2 intake and a Holley Sniper 90mm TB to get to the DBC setup.. Initially had the incorrect MAP installed, used the stock 1 bar and Fitech calls for a 3 bar.. Swapped it for the 3 bar, checked all the settings and it fired immediately, warmed up and went down to a nice idle..
    Next is the Vintage Air and then as they say, what's left is everything else:)
    The first video is of the initial start, seriously started that easy, second video is at the same time just with my phone.
    Initial start 1
    Second Video
  4. mrfleet12
    241
    34
    Aug 8, 2014
    West of Chicago IL
    Got most everything buttoned up, haven't installed the compressor for the AC because I'm waiting to shake it out to make sure there are no issues. Fitech is working ok, mostly me learning about tuning with a computer.
    A lot of lessons learned but would definitely do this again.
    Couple pics and a video, running 2.5" exhaust with Jones Mufflers, love the sound.
    roadrace2 and 71RSLS like this.
  5. 71RSLS
    725
    150
    Dec 5, 2017
    Prairie City, Ia
    Very nice!
  6. mrfleet12
    241
    34
    Aug 8, 2014
    West of Chicago IL
    Thanks, as everyone says, it's a lot of work but you won't regret it when it's done..
  7. 71RSLS
    725
    150
    Dec 5, 2017
    Prairie City, Ia
    I'm in the middle of trying to get my 71 drive able for the summer. I definitely know what you mean.
    mrfleet12 likes this.
  8. mrfleet12
    241
    34
    Aug 8, 2014
    West of Chicago IL
    Thought I'd put an update out here, I know the Fitech LS systems are still somewhat new compared to the other big names, I've got about 900 miles on it so far and it's worked really well. Made some edits to the spark table, adjusted the trans shift points and firmness and have just been enjoying the ride.
    Picked up a set of 94 Camaro seats that will go in at some point in the future.
    Now deciding if I should slide a cam in it or finish the vintage air install and just drive it for a while.
    Would definitely do this swap again, thinking 40 Chevy pickup next:)
  9. MtotheIKEo
    MtotheIKEo New Member
    Apr 13, 2015
    Reno,NV
    Looks great! Can you give some more info on your air filter/intake setup? Any part numbers?
  10. mrfleet12
    241
    34
    Aug 8, 2014
    West of Chicago IL
    This is a temporary intake, the filter is Spectre 8161, the silicone joint is from Spectre as well, the intake tube is actually a PVC Union from Menards painted black. I drilled and tapped it for the IAT. I'm running the stock Ls2 intake.
    My intent is to tuck the filter in the driver's fender like everyone else does.
    Thanks
    Bill
