73 RS bumper install
Discussion in 'Body Restoration' started by GDSmith, Mar 15, 2019.
  1. GDSmith
    GDSmith Member
    59
    Aug 4, 2012
    Glen Ellyn, IL
    Finally wrapping this drawn out adventure, went to install the front Bumperetts and based on the holes in the bumpers Somethings missing???
    There are holes for 4 bolts and only 3 places to bolt, pretty there is another piece on the outer bracket to bolt the bottom of the bumper.
    Anyone got pictures of the missing piece? Please send so I know what I’m looking for.
    Thanks in advance.
  2. GDSmith
    GDSmith Member
    59
    Aug 4, 2012
    Glen Ellyn, IL
    Appears there is a missing bracket at the outer underside for the bumper to bolt to?
    Pictures? Anyone have a pair they are willing to part with?
  3. krabben1
    8,128
    20
    May 16, 2007
    ( . Y . )Delco
    You have the correct brackets on the car for R/S,there arent anymore.Pic up your bumper.
  4. dave@ztech
    2,153
    315
    Mar 27, 2016
    NY
    I think he means , post a couple of pictures of the bumper you are installing, is it the original? When I did a search these was a bumper bracket that looked weird, however, I only remember three bolts , 2 top, 1 bottom, I have gone to sleep sense then , HAA HA , so I may have forgotten something!!
    hubedobeedo likes this.
  5. krabben1
    8,128
    20
    May 16, 2007
    ( . Y . )Delco
    There was a beefier bracket,now that Im remembering.It was 73 only.More like a plate of steel,lol.
    But youre fine with those brackets.If you had to use your bumpers,and they did have an extra hole up top that was visible,you could just fill it with another bumper bolt and be done.
  6. GDSmith
    GDSmith Member
    59
    Aug 4, 2012
    Glen Ellyn, IL
    The outlyer on the bottom at the corner is the one that has me guessing, this is the passenger side.
    If there isn’t a requirement I’m good to go!
    729D86CC-93ED-471C-AFB3-E082704AB312.jpeg 439A4F91-AFF9-48B9-96A8-F4811E2F0F79.jpeg
  7. hubedobeedo
    hubedobeedo 3rd times a charm
    75
    13
    Jul 18, 2013
    Huntertown,IN
  8. hubedobeedo
    75
    13
    Jul 18, 2013
    Huntertown,IN
    there is a production brace the part number is3986583-4 bumper 001.jpg that would mount from the core support to that lower hole
  9. hubedobeedo
    75
    13
    Jul 18, 2013
    Huntertown,IN
    i wonder if that outer lower hole was added not seen that before the brace shown is for mounting towards center
  10. hubedobeedo
    75
    13
    Jul 18, 2013
    Huntertown,IN
    i also have a set of original RS bumpers that have the same holes but i do not ever remember seeing a separate bracket for such not in manuals even. it does look like something was bolted on(rust ring)
    i wonder if it was a bracket used in 73 because of gov. law changes to get thru to 74 change would interesting to see what was there (sounds like somebody needs to find them parts)
