74 Camaro parts numbers
Discussion in '1974 Specific' started by 74BIBELOT, Jul 6, 2017.
  1. 74BIBELOT
    74BIBELOT Veteran Member
    865
    53
    Jan 19, 2006
    El Paso Tx, Cd Juarez Mx. Las Cruces NM.
    3993560 original rear drum
    A2874. Jan. 28,1974
    Max. Diam. 9.590
    3996244 windshield washer fluid reservoir with cap
    356615 overflow radiator jug with cap.
    Car is a sport coupe 02B with code K engine, th350 and A/C.
  2. 74BIBELOT
    865
    53
    Jan 19, 2006
    74 engine:
  3. 74BIBELOT
    865
    53
    Jan 19, 2006
    74 350 engine:
  4. zfool
    zfool Veteran Member
    559
    11
    May 19, 2014
    Rochester, MN
    What are you looking for ?
  5. CamaroNmotion
    CamaroNmotion Veteran Member
    326
    8
    Jan 8, 2006
    Buffalo, NY
    Just an observation. My 1974 Type LTZ28 is a 02B build also pass rear brake drum1.JPG with original brake drums date coded L1973. Both of our cars built the same week and a little over a month apart on brake drums.
  6. 74BIBELOT
    865
    53
    Jan 19, 2006
    Just got these valve covers, think they are 70 covers.
    Going to put them on my 74 Camaro with this 70 /186 heads engine.
  7. 74BIBELOT
    865
    53
    Jan 19, 2006
    70/186 heads 350 engine:
  8. zfool
    559
    11
    May 19, 2014
    Rochester, MN
    The pair you have are correct for 74. 1970 had a 3rd number with wider drippers. There is a thread on here with some good info on valve covers.
  9. zfool
    559
    11
    May 19, 2014
    Rochester, MN
  10. 74BIBELOT
    865
    53
    Jan 19, 2006
    Thanks for that info!!
    Better yet! 74 covers for a 74 Camaro.
    Now I would like to know what are the correct bolts to install them?
    Last picture from 1982 year Winter!
