74 Z - Alternator Belt (w/o Air Pump)
Discussion in 'Engine Topic' started by mgd1790, Apr 12, 2019.
  1. mgd1790
    mgd1790 Veteran Member
    982
    26
    Nov 25, 2003
    Suburban Chicago
    Does anyone which belt would work for a 74 L82 motor with standard alternator but without the air pump? I took a measurement to see what I can find at a part store.
  2. ZEN357
    ZEN357 Veteran Member
    384
    70
    Feb 12, 2018
  3. Twisted_Metal
    27,061
    997
    My 78 Camaro (305 V8) had no air pump but it had A/C.
    (I used the bracket assembly from my 78 on my 80 and kept the A/C.)
    This is the belt AutoZone shows for that setup.
    I'm pretty sure it will work for your 74.
    Personally, I use Gates belts.
    Sorry, I don't know the cross reference number for the Gates brand but I could look under the hood when I get home.
  4. 74BIBELOT
    74BIBELOT Veteran Member
    865
    53
    Jan 19, 2006
    El Paso Tx, Cd Juarez Mx. Las Cruces NM.
    I think both numbers(15450 and 15450DR)will be right for your car.
    they are 45'' long.
    If you need a little bit longer look for something like this number 15455(half inch)
  5. mgd1790
    982
    26
    Nov 25, 2003
    Suburban Chicago
    Appreciate everyone’s insight. I went to advanced auto parts and bought the 15445 and I will try that one out. Thanks again.
  6. mgd1790
    982
    26
    Nov 25, 2003
    Suburban Chicago
    I pulled that 15445 number from the link someone sent above and reference without air-conditioning and without the air pump. I will respond back if that’s a good one.
  7. 74BIBELOT
    865
    53
    Jan 19, 2006
    8A0A4F0A-BCF1-4434-BEF4-78A8809D614E.jpeg THis is from my 74
  8. mgd1790
    982
    26
    Nov 25, 2003
    Suburban Chicago
    Thanks for the picture. It looks like that 15445 is the perfect size. Thanks again.
  9. Rich Schmidt
    Rich Schmidt Veteran Member
    4,278
    38
    Mar 27, 2010
    Denville NJ
    15445 is what i have been using on regular small blocks for 30 years. I probably bought a hundred of them or more.
  10. badazz81z28
    16,912
    500
    Las Vegas, NV
    Worst case you buy a few close ones and see which fits better.
