75 Bumblebee LT4 Gen V swap
Discussion in 'Project Progress' started by SPG, Oct 7, 2018.
  1. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,405
    112
    Feb 2, 2008
    SF
    I hope that’s not true because I just priced out a speartech harness
  2. SPG
    SPG Bumblebee Builder
    456
    86
    Sep 1, 2018
    Sacramento
    I could be wrong but it didn't look like a lt1/4 with 4l75e (or 4l80e) was supported
  3. 72BIGBLOCK
    2,405
    112
    Feb 2, 2008
    SF
    I have an l76 with a 6l80
    I just spoke to him at zero gravity and I’m going with his kit instead
  4. SPG
    456
    86
    Sep 1, 2018
    Sacramento
    You'll be fine then, my setup is more unique I guess lol
  5. 72BIGBLOCK
    2,405
    112
    Feb 2, 2008
    SF
    Yeah I can tell it is
    Good luck with that
  6. SPG
    456
    86
    Sep 1, 2018
    Sacramento
    I'll most certainly need it! I'll do more research into it. I'm not locked into the lt1/4 just yet...I can still get an lsa or lsx! Can't change my tranny though, since I already got the torque converter and adapter plate....too lazy to go through the return process.
  7. SPG
    456
    86
    Sep 1, 2018
    Sacramento
    Alright, a rep from speartech got back to me, for my application I would need to select their harness with a manual transmission and get an independent controller. Anyone recommend good ones for a 4l75e? I was looking into TCI and a lot of people suggest it, input from you guys would be appreciated.
    He also suggested I contact "Rick's Tanks" to get a fuel tank and correct pump so I can replicate GM's configuration. From what I noticed they don't make a tank for my car. This is the current tank I have ready to be bought. Can anyone suggest a good alternative since this tank doesn't come with the right pump.
    I will reach out to Rick's tanks and see if they plan on making anything for my year camaro just in case.
    edit: Rick got back to me, wanted $1900 for a tank and fuel pump...I think I died a little inside....but that's primarily due to the fact it would need custom fabrication work since they don't carry my tank. I'll do some research when I get home.....$1900 for a strap on fuel tank is absurd in my opinion.
  8. BonzoHansen
    19,636
    902
    Jun 1, 2005
    Scott from Hamilton, NJ
    I'm having trouble keeping up with all this. Are you still using the modern LT1 motor the direct injection one?
  9. SPG
    456
    86
    Sep 1, 2018
    Sacramento
    I'm on the fence between an lt1 and lt4 from a modern camaro/corvette.
    I don't want an LS, and I know going with an LT makes this more complicated...that's what makes it fun (and sadly more expensive)
    Right now I'm strongly considering just going for the lt4 and calling it a day, if I get an lt1 it would be so I just buy a super charger later.......but why not just buy it all now right?
    I know I've been a bit wishy washy, and that's primarily because what I originally bought I was told wasn't going to work so I got all my money back and started to do more research on the subject.
  10. BonzoHansen
    19,636
    902
    Jun 1, 2005
