75 Camaro frame deminsions
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Radio, Dec 2, 2019.
  1. Radio
    Radio Member
    92
    11
    Oct 9, 2013
    TULSA, OK
    I'm looking for the frame mounting hole dimensions for a 75 base model.
    I've looked at both sets of dimensions in the file section and neither one of those match the dimensions to my frame
  2. Fbird
    4,311
    763
    Feb 12, 2011
    atlanta, ga
  3. Radio
    Radio Member
    92
    11
    Oct 9, 2013
    TULSA, OK
    I may have to measure the car.
    Thanks for the link.
  4. 79T/Aman
    2,573
    191
    Oct 7, 2004
    Dickson TN.
    remember 70-74 have the rear holes in a different location than 75-81.
  5. Fbird
    4,311
    763
    Feb 12, 2011
    atlanta, ga
    also recommend the subframe connector thread too....info on the early vs late dims.
  6. Radio
    Radio Member
    92
    11
    Oct 9, 2013
    TULSA, OK
    I used the dimensions in this thread
    http://www.nastyz28.com/tech/framechk.html
    My holes were off by about 2" compared to the body.
    If there is some info that you need to point me in the right direction I'll be able to get it to you on Wednesday evening.
  7. 79T/Aman
    2,573
    191
    Oct 7, 2004
    Dickson TN.
    Post a picture of the frame showing the rear hole.
    you need to tell us what holes are off and in what direction.
    I suspect it is closer to 3" off at the rear one, so you may have a 70-74 frame
    I make conversion plates if you need, they locate off your existing hole and gives you the correct location for the next hole. frame 013.JPG frame bushing holke repair 012.JPG
    Radio likes this.
  8. Radio
    Radio Member
    92
    11
    Oct 9, 2013
    TULSA, OK
    So is that dimension exactly 3" forward from thereat hole?
    The forward holes on the rear body mount is what my car is.
  9. 79T/Aman
    2,573
    191
    Oct 7, 2004
    Dickson TN.
    post a pic of the frame
  10. Radio
    Radio Member
    92
    11
    Oct 9, 2013
    TULSA, OK
    I will tonite
    I have the early frame according to the pic above and need the late frame.
    I'll double-check my measurements but I'm pretty sure I cut the hole according to the dimensions on the link I posted
