77 Z28 LT mystery roof hole
Discussion in 'Body Restoration' started by Scott51, Jun 18, 2019.
  1. Scott51
    Scott51 Veteran Member
    627
    74
    Jan 2, 2012
    New Zealand
    Just got my 77 back from media blasting and it exposed a 1” hole in the roof skin above where the rear view mirror would normally be (front centre). There’s also some kind of pressed nut stuck to the inside of it and a corresponding bolt hole on the inner skin.
    It all looks factory but can’t work out what was there so before I go blindly digging through my interior parts, does anyone know what it’s for and what it would have been filled with originally?
  2. 70lt1z28
    3,441
    682
    Oct 3, 1999
    Beavercreek, Ohio, USA
    During that time-frame, maybe a CB antenna?
  3. xten
    xten Veteran Member
    2,983
    1,745
    Sep 24, 2014
    Pittsburgh, Pa.
    I would think it would be for some sort of professional radio, possibly two way.To get the nut on the inside of the roof skin, one would have to at least partially take a headliner down. Can't see a CB'er or even a ham operator going through all that, since antennas were available that clamped to panel edges, drip rails, or magnetized. In any case, I would think some sort of antenna. Do you have any history on the car Scott?
    budro6968 likes this.
  4. budro6968
    budro6968 Veteran Member
    3,286
    528
    Apr 2, 2016
    Jax Florida
    My 78 Z had a hole in the center of the deck extension. Same thing CB Ant. That's A BIG 10-4....
  5. BonzoHansen
    19,445
    799
    Jun 1, 2005
    Scott from Hamilton, NJ
    That's weird in the front like that
  6. badazz81z28
    16,991
    522
    Las Vegas, NV
    Pics?
  7. Scott51
    627
    74
    Jan 2, 2012
    New Zealand
    Not much to look at, will have to get some better pics tonight and maybe hit it with the wire wheel.
    Only history I have on the car is that it was imported into NZ from Japan, by an American serviceman working in the Naval base in Christchurch.
    First thought was also antenna but the car already had a pretty big one installed on the rear quarter when I got it, and the holes and the captive nut look like factory work.
    BTW the lump in the centre of the hole is the end of a 1/4” or 5/16” bolt the blaster put in before painting
  8. xten
    xten Veteran Member
    2,983
    1,745
    Sep 24, 2014
    Pittsburgh, Pa.
    That's just strange. No clue.
  9. Scott51
    627
    74
    Jan 2, 2012
    New Zealand
    Hmmm might have to dig out my old headliner and few of the other parts I removed to check if I still need it or should weld it up
  10. CorkyE
    10,403
    485
    Could it have been a police vehicle in one of it's lifetimes - bubble gum machine mount?
