78-81 camaro instrument cluster identification
Discussion in 'Electrical Systems' started by 70camaro4sho, Dec 11, 2013.
  1. 70camaro4sho
    70camaro4sho Veteran Member
    115
    Mar 19, 2011
    Houston, Tx
    Can anyone please help my brother dentify which instrument cluster this is and can he use it on my 1980 camaro? Also can anyone let me know of a place that will sell the rear wiring section, not sure what its called but its destroyed.. thanks to all
  2. COPO
    17,685
    683
    1976-78 U14 Pkg? Note batt volts.
    Someone replaced the OEM temp gauge and clock on the far right with aftermarket gauges.
  3. iraqivet
    iraqivet Veteran Member Lifetime Gold Member
    470
    24
    Nov 7, 2012
    Hobart, Indiana
    Cluster
    The cluster will fit but there are a couple of things:
    The oil pressure gauge is not stock, the clock was there.
    The gearing in the transmission will need to be changed so the Speedo works correctly. The rear tire size also has to be factored into what drive and driven gears you put in the transmission.
    Try NPD, Classic industries, Rick's Camaro, F body warehouse for the Instrumentation Printed Circuit board found on the back.
  4. Twisted_Metal
    26,949
    932
    That's a 79 cluster. (One year only speedometer.)
    Long orange needles with a 130 MPH speedo.
    Oil pressure gauge was added and the right turn signal stalk is busted.
    It will fit the 80 with no problem.
    (I have a 79 cluster in my 80 because I didn't like the 85 MPH speedo.)
  5. 70camaro4sho
    115
    Mar 19, 2011
    Houston, Tx
    Thank u all for all the awesome fast info!! I will b sure and pass along the info to my older brother. U guys rock!!!
  6. 79zBlue
    79zBlue Veteran Member
    259
    Apr 7, 2012
    long island ,NY
    I see the needle is busted in the volts
  7. BonzoHansen
    19,357
    726
    Jun 1, 2005
    Scott from Hamilton, NJ
    that thing is a mess
  8. mickstan
    mickstan Veteran Member
    927
    Jun 11, 2012
    E'ville, IL
    Twisted Metal, what identifies that speedo as a '79?
  9. mickstan
    927
    Jun 11, 2012
    E'ville, IL
    never mind...............
  10. KansasTwister
    KansasTwister Veteran Member Lifetime Gold Member
    1,389
    Oct 7, 2006
    Lawrence, ks
    78 was same style as 70-78, I dont know them as well.
    79 was 130mph speedo.
    80 excluding cali cars was 85mph speedo no check engine light.
    81 and 80 cali cars had a check engine light, 85mph
    79-81 had the long orange needles.
