78' Camaro LT1 Conversion Cali Smog Legal
Discussion in 'High Tech Retrofits' started by supwicha, Feb 26, 2014.
  1. supwicha
    supwicha Veteran Member
    182
    14
    Feb 23, 2014
    Victorville, CA
    Yes I did run into a clearance problem. I had to cut the shock mount off of the left perch and relocate which has changed the geometry a little. I'm probably going to to do a better modification in the future.
  2. tj_in_nm
    tj_in_nm New Member
    Apr 21, 2017
    Las Cruces, NM
    Crap, that's what I was afraid of. Maybe running a passenger side backing plate on the driver's side would work - stagger the calipers WS6-style.
    Did you hook up the parking brake?
  3. supwicha
    182
    14
    Feb 23, 2014
    Victorville, CA
    Actually, I had not considered that idea. That might just work. No, I have not yet hooked up the parking brake cable. I will have to do some improvisation on that like everything else :) Hope to see your project progress.
  4. supwicha
    182
    14
    Feb 23, 2014
    Victorville, CA
    Again, after far too long of not working on it, I got the bug again to keep pressing on. Classic industries had a sale so I bought a cowl hood, hinge pins/bushings, inner door handles, and rear package tray. Everything out the door was only $346!
    What the heck, photobucket wants $400 to host photos? Sucks, none of my photos work except these. I'll have to update all of them, major bummer.
    [/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
  5. supwicha
    182
    14
    Feb 23, 2014
    Victorville, CA
    Ordered my wheels (two showed up today). Going with 20"x8.5 in the rear, 18"8 in the front.
    Also replaced the front cracked windshield with a new one ($175 installed).
    Pulled out the back glass to fix the one and only spot of rust on this car. Stripped and cleaned the channel and applied a rust seal. Need to do some welding/grinding then re-install the glass.
  6. Jas0n
    Jas0n Veteran Member Lifetime Gold Member
    1,023
    20
    Apr 27, 2010
    Verona, ITALY
    Those rims are biiiiiiiiiiig! Beautiful!!
  7. supwicha
    182
    14
    Feb 23, 2014
    Victorville, CA
    Been fixing my photobucket destruction. About 1/2 the way through the fix. Sucks what they did. . .
  8. 8pack
    2,617
    148
    Aug 29, 2007
    Western, MA
    Are you using imgur or something else. I started and tried Google photos but couldn't get it to work.
  9. supwicha
    182
    14
    Feb 23, 2014
    Victorville, CA
    Yes, I am using imgur.
  10. supwicha
    182
    14
    Feb 23, 2014
    Victorville, CA
    About 90% finished fixing the Photo Bucket debacle. . .
    Jas0n likes this.
