78' Camaro LT1 Conversion Cali Smog Legal
Discussion in 'High Tech Retrofits' started by supwicha, Feb 26, 2014.
  1. supwicha
    supwicha Veteran Member
    182
    15
    Feb 23, 2014
    Victorville, CA
    Thank you kind sir :)
  2. supwicha
    182
    15
    Feb 23, 2014
    Victorville, CA
    To Polish or Not to Polish?
    Do any of you have any experience with polishing aluminum on a bench polisher? I want to polish the aluminum fuel rails that mount on top of the intake before I set up the fuel system. Thanks in advance for your suggestions!
  3. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    Yup, been there done that.;)
    I have often thought of copying my build thread over on this forum, but it seems
    that pretty much each area is a "High Tech Retrofit" down to hands free phone.
    See sig link for plenty of reading material.
    Tom
  4. Da-bigguy
    4,145
    274
    Jan 19, 2010
    Cypress, TX
    That engine looks fantastic! I love how the paint makes it look anodized!
  5. supwicha
    182
    15
    Feb 23, 2014
    Victorville, CA
    Well, after much too long of a break, here is the latest updates. Pulled subframe, stripped, cleaned, KBS coatings 3-part kit application, energy suspension mounts (have energy system for the entire car), mocked up the engine onto the frame and now to notch/pocket the frame to clear the A/C.
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
  6. supwicha
    182
    15
    Feb 23, 2014
    Victorville, CA
    That's all for tonight. Need to decide if I want to purchase a ready-to-go cross member or pull out the plasma cutter and mig :)
  7. Jas0n
    Jas0n Veteran Member Lifetime Gold Member
    1,028
    23
    Apr 27, 2010
    Verona, ITALY
    Nice mock up! subframe turned out fantastic!
  8. supwicha
    182
    15
    Feb 23, 2014
    Victorville, CA
    Thanks Jas0n :)
  9. sbca96
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    As per our PM chat, there are benefits to buying some things out of a catalog to
    move the project along. That said, I did not remove the subframe and have that
    level of access you have there. I fear sending you measurements to use, if for
    some reason things do not line up. I had access to the '78 Camaro until today I
    needed to make room in the garage yet again for the wifes oil leaking LS Camaro.
    Frame notch help is here :
    http://www.nastyz28.com/forum/showthread.php?t=160332
    700R4 cross member help :
    http://www.nastyz28.com/forum/showpost.php?p=3081062&postcount=2
    and
    http://www.nastyz28.com/forum/showthread.php?t=144498
    also here :
    http://www.hotrodders.com/forum/700r4-my-78-camaro-230074.html
    You also may want to bolt the passenger side upper control arm on, the one on
    our Camaro had molecular overlap with the LT1 accessory bracket. I cover this
    in my install thread below.
    If you need a shifter, I have a 700R4 B&M Megashifter I can sell, similar to :
    Tom
  10. supwicha
    182
    15
    Feb 23, 2014
    Victorville, CA
    Hi and thank you for the great information. I would like to keep the stock shifter and change the detent's to the shiftworks model. I have seen the necessity to radius the accessory bracket to clear the passenger side upper control arm. My plan is to do as many of the mods as possible while sitting on the frame. I have a plasma cutter and mig, so I'll notch and pocket the frame without any troubles. I'm hoping to set up the primary exhaust where it sits as well. Since my doner vehicle was a '95 Caprice Police Cruiser, it has factory dual exhaust and dual cats which I still have. I'm hoping not to have to use the electric air pump. The pump was removed and a decal was mounted on the radiator support that it was removed per the factory TSB xx.xxx. I called the referee and he said "yes", but said to keep the decal which I have. Did you keep your air pump? Thanks again!
