78' Camaro LT1 Conversion Cali Smog Legal
Discussion in 'High Tech Retrofits' started by supwicha, Feb 26, 2014.
  1. supwicha
    supwicha Veteran Member
    182
    15
    Feb 23, 2014
    Victorville, CA
    Actually worse, grade nothing bolts. These are temporary while I mock up the remaining components. I still have some stiffeners to weld, top plate and quality hardware. Thanks!
  2. supwicha
    182
    15
    Feb 23, 2014
    Victorville, CA
    That's exactly right :)
  3. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    That should do nicely.
    Tom
  4. supwicha
    182
    15
    Feb 23, 2014
    Victorville, CA
    Subframe Install
    Nothing special to note here. Just protected the frame, installed all new polyurethane mounts and mounted the frame. I have in the process created more work for myself however. With all the projects, dirtbikes, and everything in the garage, I just need to recover some space. So with that, I'll have to protect the frame while I finish stripping the firewall and prep for paint. Yea, I know, in reverse order but I need some space back NOW :)
    [​IMG][/IMG]
    [​IMG][/IMG]
  5. supwicha
    182
    15
    Feb 23, 2014
    Victorville, CA
    Ok, managed to strip my firewall, sand, degrease, primer, and paint today. I went with an automotive black matte for the color. Got the engine stabbed too. I still need to remove the inner fender wells for prep and paint but I at lest got the engine off my floor and out of the way. Next up: Suspension install. PS - One piece of advise. I really do like Energy Suspension and their products, but I'll never use their engine mount on the clam shell type mounts again. These are the worst buggers to install ever. They will really test your patience.
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
  6. supwicha
    182
    15
    Feb 23, 2014
    Victorville, CA
    Here are a couple of the engine, no too good though, poor lighting. I'll post better detail shortly. Also verified my AC compressor clears perfectly after the subframe mod.
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
  7. sbca96
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    Sure is purdy.:)
    Tom
  8. vdavie
    vdavie New Member
    28
    Aug 11, 2004
    sunnyvale,cal
    Hello,
    I live in Norcal and i was scared to touch anything on my 80 z28 because of the smog laws. How are you getting around that? Would love to do some head work ect.. to the motor. Any suggestions?
    Thanks,
    Vince
  9. sbca96
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    I got asked this question on youtube for my pass video a couple years ago. The
    way that you do it in California .. is dump the old school engine and smog stuff.
    The laws are too restrictive to do much of anything to the stock equipment, but
    if you install a newer engine, you fall under the laws of the newer engine. It will
    be smogged AS that year car.
    That said .. if you want to improve your stock equipment, you can look for CARB
    approved speed parts, there are just less available for 1976-1981 years.
    My wife took the '78 LT1 swap to a car show in Northridge at the Bobs Big Boy a
    few weeks back and the car got a LOT of attention. Smog year F-body cars are
    the unicorn these days in California. They were shocked to see one on the road
    let alone with an EFI engine and OD trans. Tons of questions, comments on how
    good it sounded pulling up .. even before the hood was opened.;)
    Tom
  10. vdavie
    vdavie New Member
    28
    Aug 11, 2004
    sunnyvale,cal
    Thanks for the info. I was always told you would fail the visual.
    vince
