78 camaro wont start.
Discussion in 'Troubleshooting & Diagnosis' started by SpoofytheWhale, Nov 15, 2019.
  1. SpoofytheWhale
    SpoofytheWhale New Member
    8
    Nov 15, 2019
    So the past couple days the Cam has been giving me a lot of issues starting up. Over time it would take longer and longer to get the engine to crank over. I have replaced the battery, the alternator, starter. It cranked over 3x then nothing. I then replaced the ignition switch, and the neutral safety switch. And now it wont crank at all, no clicks, nothing at all. Any help would be greatly appreciated.
  2. EVILFACE
    EVILFACE Veteran Member
    139
    32
    Sep 6, 2013
    Yukon, OK
    neutral safety switch or it’s wiring.
  3. Twisted_Metal
    27,087
    1,012
    Bad battery cable?
    Sometimes they corrode internal to the insulation.
    Check for power at the starter and the solenoid crank trigger connection with someone turning the key.
    Good Luck!
  4. Vettenick
    Vettenick Vettenick
    104
    19
    Jul 17, 2019
    Did the no crank situation happen after you replaced the ignition switch and the neutral safety switch? If so, just make sure the connectors are all the way in, and make sure the ignition switch is properly adjusted. If the ignition switch is out of adjustment, you'll get that "dead" condition.
  5. bourbon_scotch
    2,402
    143
    Jan 10, 2003
    USA
    Take the trigger wire off the solenoid on the starter and run a positive test wire to the solenoid on the starter.
  6. SpoofytheWhale
    8
    Nov 15, 2019
    Yup it was right after. I'm wondering if it has anything to do with the difference in the two safety switches.
  7. bourbon_scotch
    2,402
    143
    Jan 10, 2003
    USA
  8. Vettenick
    Vettenick Vettenick
    104
    19
    Jul 17, 2019
    Just like the ignition switch, there are adjustment slots. What did you do to confirm that both switches are adjusted properly?Just a tip that I learned a long time ago.....when you replace things to solve a problem, do it one at a time, so you can determine what effect that change made. I would guess that one or both might be out of adjustment.
    dave@ztech likes this.
  9. SpoofytheWhale
    8
    Nov 15, 2019
    I started from scratch one by one. First started with the neutral safety. Placed the gear in Neutral and made sure the switch was placed in neutral secured in place with a pin. Bolted it down, connected wires then removed pin. Then worked on the ignition switch. Placed the ignition lock in the off position, then the ignition switch to the off position in the center. Aligned it with the rod, bolted it in. Turned key and nothing. The buzzing, dash, all come on.
  10. Gary S
    22,592
    811
    The buzzing and dash lights coming on indicate that the ignition switch is likely not the problem. You can easily check the neutral safety switch. Put a voltmeter in the contacts of the neutral safety switch plug. One should have 12v. The other one will be switched with the shifter. If you have that, it is working. If the switched one isn't showing power, then it is either a bad switch, or more likely misadjusted.
    GoldenOne7710 likes this.
