79 "unleaded fuel only" decal
Discussion in '1978 - 1981 Specific' started by seventy7camaro, Jun 10, 2019.
  1. seventy7camaro
    seventy7camaro Veteran Member Lifetime Gold Member
    1,385
    23
    Feb 6, 2005
    Covington, Virginia U.S.A.
    Can someone post a pic showing the factory correct decal on the back bumper? Also, is it 4" or 5" long?
  2. Zspoiler
    Zspoiler Veteran Member
    3,033
    219
    May 6, 2012
    Federal Way, Washington
    Have you tried Rick`s Camaros parts.
  3. budro6968
    budro6968 Veteran Member
    2,937
    434
    Apr 2, 2016
    Jax Florida
  4. Glava
    Glava Veteran Member Lifetime Gold Member
    364
    8
    Mar 23, 1999
    Central NY
    About 3 1/2" -this is the original on my 79 Z28
  5. seventy7camaro
    1,385
    23
    Feb 6, 2005
    Thanks Glava for the pictures and for backing them up with a rule. Just about all the Camaro catalogs offer decals but knowing which is correct is where the problem was.... problem solved.
    One last question... My space saver spare does not have a decal on the rim and I'm seeing that they were on there up to '77 but there's none listed for '79... is that correct?
  6. Glava
    364
    8
    Mar 23, 1999
    Central NY
    This is
    This is what mine has on it -I had put a full size spare in it for the early years, when I drove it as my DD and then put it back in when I wasn't driving it so much.
  7. seventy7camaro
    1,385
    23
    Feb 6, 2005
    Can you see a tire size mentioned on the inflater bottle?
  8. Glava
    364
    8
    Mar 23, 1999
    Central NY
    Sorry, I'll pull it out again today and get that -it is on the inflater and just didn't show in the picture.
  9. Glava
    364
    8
    Mar 23, 1999
    Central NY
    Had to get the Z28 back down on the lift -here you go!
  10. seventy7camaro
    1,385
    23
    Feb 6, 2005
    Thanks for the info. I'm wrapping things up on my car and it's the little things that need the most attention.
