79 Wiring
Discussion in 'Interior Restoration' started by Tallguy2o0o, May 4, 2004.
  1. Tallguy2o0o
    Tallguy2o0o Veteran Member
    429
    May 25, 2002
    Poughquag, NY, USA
    I need to find the wire that is used to dim the instrument panel in a 79 camaro, what color is it? how can i find it? where is it comeing from? i need it so i can hook it up to new guages i bought to put under my radio. The color would be a big help and where the wire might be located also, thank you.
  2. 79ZED
    79ZED Veteran Member
    3,080
    Jan 31, 2000
    Nanaimo, B.C., Canada
    Tallguy2o0o,
    The wire your looking for is grey and it goes from the headlamp switch to the instrument panel connector. The grey wire can also be found at the heater control and radio illumination connectors.
    Hope this helps,
    John
    79Z28
