8.5 10 bolt high pitch whine
Discussion in 'Transmission & Driveline Topics' started by haroldpo6, Sep 2, 2019.
  1. haroldpo6
    haroldpo6 Veteran Member
    325
    May 9, 2015
    PC Fl
    Had my 8.5 rebuilt with new gear & pinion w/bearings, seals, axle bearings,etc from a guy that has rebuilt them a lot. It has a high pitch whine between 2000rpm and 2500rpm then quits. He said he took it back apart 3 times and can find nothing wrong.
    Whats wrong with it?
    Its a 1976 rear axle I installed in a 1970
  2. camaro71/holland
    1,219
    76
    Aug 27, 2003
    The Netherlands
    If he's 100% positive about the setup it could be the way it's cut. Then you just can't get it right. Richmond gears BTW?
    Or it wasn't right the first time and you drove too long with it. Then you won't loose it, no matter how good the latter setup will be.
  3. badazz81z28
    16,597
    439
    Las Vegas, NV
    My last 8.5 was using Richmond gears with no issues. Are you positive it’s the rear? Rule out the rest of the driveline?
  4. haroldpo6
    325
    May 9, 2015
    PC Fl
    Used motive gear and master bearing kit from them also. He said he has it right, can't understand the whine. Only drove a few miles so far.
  5. big gear head
    big gear head Veteran Member
    6,178
    80
    Jul 30, 2001
    Central City, Ky.
    Most of the time a gear noise has nothing to do with RPMs. Gear noise is usually related to MPH. If it's a 2 cut gear and he set it up like a 5 cut gear then the backlash may be too loose. Sometimes a gear just makes noise no matter how wel it's set up, especially if it was a cheap gear.
  6. haroldpo6
    325
    May 9, 2015
    PC Fl
    Yea, I used rpm because MPH is off for now. Went from 2.73 to 3.08 so between 50mph to 60mph is the worst.
  7. cadillac_al
    cadillac_al Veteran Member
    832
    85
    Apr 22, 2015
    Maine
    Has the rebuilder heard the noise? You would think he would have some kind of idea what's going on or maybe he could rule out the gears altogether.
  8. big gear head
    6,178
    80
    Jul 30, 2001
    Central City, Ky.
    2.73 to 3.08 isn't much of a change. Did you use new or used gears? Used gears can be difficult to set up.
  9. haroldpo6
    325
    May 9, 2015
    PC Fl
    New gears, and Tony heard the whine, he called and told me what was happening. Said he took it apart 3 times and could find nothing wrong with the set up. I'm thinking china cheap gears. Tony sets up rear ends for the local racing guys. He said he has no clue what it could be. I'll live with it.
    Thanks guys.
  10. badazz81z28
    16,597
    439
    Las Vegas, NV
    I’m using US Gear (made in USA). If you change it out look to them
