9" ford ring gear noise
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by idtem, May 3, 2012.
  1. JONESYFXR
    JONESYFXR Veteran Member
    2,177
    Oct 10, 2009
    BUFFALO, NY
    That's awesome!!! Let us know how things go!!
  2. Cardinal
    8,281
    33
    Jun 22, 2003
    Endicott, NY
    WOW! I'm impressed!
    Keep us posted.
    Post pics of the rear gears when you take out the carrier.
  3. idtem
    idtem Veteran Member
    140
    Feb 8, 2011
    Overland park, Kansas
    Just thought I would update you on the status of the ring gear. Heidts support is very good!
    This Month I had the local Hotrod shop ordering me new upper and lower tubular A-arms from Heidts and at the same time Heidts just sent them a new ring gear for free. Just thought I would let you know they support their product. I am very impressed! I haven't had the car on the road yet to see if this gear is quieter or not though.
    I am having the Hotrod shop put in a new 496 stroker and the Heidts upper/lower a-arms and coil over shocks. I can't wait to see how it drives.
    They said I may have it this weekend.
    I wanted to thank you all for your help during this project!
    This is an awesome website.
    Here's a pic of it from today.
  4. badazz81z28
    16,949
    506
    Las Vegas, NV
    I’m ready for a new 3rd member! Not only is it noisy, now the pinion support is leaking! Geez!
  5. dave@ztech
    3,479
    714
    Mar 27, 2016
    NY
    How long did you own that rear before it caused problems, the OP had a problem at 150 miles or the start of his new install.
  6. badazz81z28
    16,949
    506
    Las Vegas, NV
    Day 1, Moser told me it was pinion angle.
  7. Zulu28
    Zulu28 Veteran Member
    287
    22
    Dec 19, 2013
    Vancouver, BC
    That response sounds like a Disclaimer not a fix...I have a new Strange diff center with 4:11 which I'll be swapping out, it'll be interesting to see how everything was set up, good luck with the pinion angle brush off, I guess Moser thinks we're all idiots!
  8. camaro71/holland
    1,237
    86
    Aug 27, 2003
    The Netherlands
    Ok, I'm a noob compared to guys at Moser, but howling R&P due to pinion angle that's hard to believe for me... Drive shaft vibration leading to a leaking seal ok, but howling?
  9. badazz81z28
    16,949
    506
    Las Vegas, NV
    935F8366-1730-4229-BA16-7A37AFC1F7B3.png I told them that. Even in good faith I went and adjusted it all over the place and not the slightest change. The leak is coming from the bearing support where it meets the housing.
    This seal
