'94 Firebird LT1 into '78 Camaro project back on
Discussion in 'High Tech Retrofits' started by sbca96, Jun 21, 2010.
  1. SupplySgt
    SupplySgt Veteran Member Lifetime Gold Member
    1,374
    Jun 20, 2009
    Finally back home!!!
    Very nice install!
  2. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    Got rid of the last wire nut and wrapped some wires in split loom....
    A little more presentable ...
    Tom
  3. 78ls1Swap
    78ls1Swap New Member
    20
    Nov 9, 2013
    Victoria, Texas
    Thanks again for the information about the motor mounts. I was able to get the mounts i wanted to work afterall. Your build is inspirational.. just putting few touches on mine. Thats cool. I just saw your post now where u put the ecm. I wanted to putmine in same place. Sweet i know now it will fit.
  4. 78ls1Swap
    20
    Nov 9, 2013
    Victoria, Texas
    Tried to post a pic of my build. But, heres the link
  5. supwicha
    supwicha Veteran Member
    182
    15
    Feb 23, 2014
    Victorville, CA
    Accessory Bracket Question
    I too am doing a '78 LT1 California Smog Legal conversion, just started a few weeks ago Located HERE:
    http://www.nastyz28.com/forum/showthread.php?t=275555
    Question: On the accessory bracket, I want to keep the AC compressor. Do you know if it has sufficient clearance? Or does the sub frame need to be pocketed? I understand it will need to be notched to clear the control arm, will the suspension interfere? I'll be watching your thread to see how yours comes along too.
  6. sbca96
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    I not 100 percent clear on your questions, but I will try to help.
    AC Compressor will NOT fit where it mounts on a B-body (yours) or F-body (mine)
    only the Corvette LT1 (which is on top drivers side). In order to use the lower
    mounting point, you have to notch the subframe. I didnt want to go that route.
    My plan was to get the Bowers setup (Corvette location) and run Corvette hoses.
    http://www.bowersrodshop.com/old/info_pulley_j.htm
    They also sell the AC delete pulley, which is a copy of the GM I used. It puts the
    compressor right back where it was originally on a 2nd Gen.;)
    The accessory bracket (Alt/PS/AC) needs to be notched to clear the front upper
    bushing on the control arm. I have a few pictures of this contact. It was so bad
    in my case the passenger side motor mount wouldnt line up.
    I wont be tackling the AC compressor install any time soon, so watching my thread
    for that info wont "come along" for a while. As far as the swap, make some coffee
    and start reading ... I am already approaching my first "regular" smog test in April!!
    This will be the first official use of the BAR sticker. My smog guy already saw the
    car though, I brought it by after we passed the BAR inspection on the first try.:cool:
    Tom
  7. 78ls1Swap
    20
    Nov 9, 2013
    Victoria, Texas
    Fits nice and just about done. thanks for all your help
  8. 78ls1Swap
    20
    Nov 9, 2013
    Victoria, Texas
    side view
  9. 78ls1Swap
    20
    Nov 9, 2013
    Victoria, Texas
  10. 78ls1Swap
    20
    Nov 9, 2013
    Victoria, Texas
