a/c hole?
Discussion in 'Body Restoration' started by tims78camaro, Jul 25, 2019.
  1. tims78camaro
    tims78camaro Veteran Member
    589
    Aug 6, 2008
    louisville ky
    if i fill in the a/c hole on the firewall can i still have heat cause somebody told me i couldnt and i thought the only thing that ran heat was the box behind the fire wall
  2. Zspoiler
    Zspoiler Veteran Member
    3,148
    239
    May 6, 2012
    Federal Way, Washington
    You can use a non AC heater box And it will work. I kept the AC heater core and just ran the heater hoses different from non AC cars
  3. tims78camaro
    589
    Aug 6, 2008
    louisville ky
    well i welded a piece of metal in mine will it still work that way or will i have to go with an electric heater systems i have seen
  4. Zspoiler
    3,148
    239
    May 6, 2012
    I used my stock electric fan.Its the same AC or not.
  5. BonzoHansen
    19,286
    693
    Jun 1, 2005
    Scott from Hamilton, NJ
    No.
    This might help visualize. what's under the dash matches the firewall opening. Even the non ac cars have openings but its different and has matching under dash parts.
    http://www.nastyz28.com/threads/true-z28.309515/#post-3537919
    If you want to keep your current heat get an AC deletd box.
  6. tims78camaro
    589
    Aug 6, 2008
    louisville ky
    the only reason im worried about heat is cause of defrost i just thought the hole was there was for the ac isnt there electric ones that will work that you dont have to have the hole there
  7. Scott51
    Scott51 Veteran Member
    612
    69
    Jan 2, 2012
    New Zealand
    The blower/fan pulls air from the round hole behind the fender and pushes it through the rectangular hole in the firewall.
    The electric ones suck so if you want an easy bare bones defrost setup
    1) get this https://www.classicindustries.com/product/all-years/chevrolet/camaro/parts/14444.html
    2) Gut the factory heater box, replace the heater core, blank off all outlets except the one that goes to the windscreen ducts and wire or glue the x2 gates open/shut so the air passes through the new core and to the windscreen ducts
    3) wire up the switch of your choice to operate the blower motor with the help of a relay. My 77 had the optional rear Defog paddle switch on the dash so I used that, but you can also reuse the factory one or any 2-3 position switch.
