a carb on an lt1??? Please HELP!!!!!!!!!!!!!!!!!!! PLEASE???
Discussion in 'High Tech Retrofits' started by angelz28, May 8, 2008.
  1. angelz28
    angelz28 Veteran Member
    356
    Apr 25, 2006
    Guatemala Central America
    my friend have a lt1 out from a caprice 96. But no computer, only manifold and fuel inyectors.
    ok I donk know nothing about fuel inyection ok!
    i know that summit sales NAL-24502592 ( carb manifold), but what about the distribuitor?? does my edelbrock carb fits??
    what about my heathers???
  2. 77LT1
    77LT1 Veteran Member Lifetime Gold Member
    719
    Jan 29, 2007
    Jax, FL
    If this isn't a complete LT1 engine I would stay away from it. It is basically a Gen 1 engine on the outside but everything else is LT1 reverse cooling specific. Your biggest hurdle that I can see is the opti. I've seen people convert them to distributors but why go through the hassle. Also, make sure it's a 5.7 litre. There were some "baby" LT1s that had much smaller displacement. If you have one of those they're not worth anything really.
    If it were me and my money, I would go find some Gen 1 engine and rebuild it. Much easier and much cheaper. Take it from someone that has built a 383 stroked LT1. If I didn't already have everything from a donor car, I never would've built it.
    My .02
    B
    BTW Regular Camaro headers will fit it. The LT1 is D-port and the "regular" small block is round port. They are different, but, they will work just fine.
  3. angelz28
    356
    Apr 25, 2006
    ok thanx
  4. angelz28
    356
    Apr 25, 2006
    i like the lt1 because the roller stuff and the heads
  5. AJ_72
    AJ_72 Veteran Member
    5,129
    Jul 3, 2003
    Chebanse, IL USA
    Get a 1987 or later block out of an F-body (L98 in the Firebird, Camaro), B-body (LO5 in the Caprice, Roadmaster) or a Y-body (L98 in the Corvette) and you've got your roller stuff.
    Or you can get lucky, as I did, and get an LO5 out of a 1987 or newer truck which has the roller cam provisions. It's a rare occurrence, but it happens. The casting number is 14093638
    The Vortec heads were designed from the cast iron LT1 heads.
    If you can find an L31 out of a 1996 or newer GM truck, it's a roller cam block and will already have the Vortec heads.
    L31 applications:
    * 1996-2003 Chevrolet Express/GMC Savana full-size vans
    * 1996-1998 Chevrolet/GMC C/K full-size trucks
    * 1996-1999 Chevrolet Suburban/GMC Suburban full-size long-wheelbase SUVs
    * 1996-1999 Chevrolet Tahoe/GMC Yukon full-size short-wheelbase SUVs
    * 1999-2000 Cadillac Escalade
    TBI L31 applications
    * 1996 G-series Vans over 8,500 GVW w/ 4L80E
  6. luda
    luda Veteran Member
    1,215
    Oct 1, 2002
    Eastern NC
    if you've got tons of money, the LT1 (assuming it's the 5.7L) is a heck of an engine. they're amazingly fun off the line (though i'd still make it fuel injected).
    if you don't, i'd do like they said...go vortec 5.7L. i've got a 75 block with vortecs and a few extra goodies and it'll smoke a 2.41 peg leg for 30+ yards. gotta get those 3.23s and some posi in...blah
  7. angelz28
    356
    Apr 25, 2006
    so. Can it be done??' yes or not???
  8. 77LT1
    719
    Jan 29, 2007
    Jax, FL
    It can be done, but, it will be $$$. Like I said before, if you don't have everything it'll cost more than just doing a late model vortec.
    B
  9. Mike1970RS
    Mike1970RS Veteran Member
    182
    Jul 23, 2005
    Monroe CT
    You can use a LT1 with a regular SBC distributor . You can keep the carb also the intake has both carb patterns. If you pull the opti off GM sells a cover or make you own . You can run the stock water pump or go electric water pump . If going electric a double roller timing chain can be used , just have to grind the timing cover for clearance.
  10. angelz28
    356
    Apr 25, 2006
    mmmm think ill go with the traditional water pump thanx!!!;)
