A new Camaro owner...again...
Discussion in '1970 - 1973 Specific' started by gpm6367, Jun 19, 2019.
  1. gpm6367
    685
    28
    Feb 12, 2005
    New Joisey
    West Coast car her entire life. :)
  2. gpm6367
    685
    28
    Feb 12, 2005
    New Joisey
    EDB348CA-7F90-4F56-9025-CFE3DE1D568E.jpeg 994FEAA3-4906-490E-B38A-5A5247588E6C.jpeg 3DFA6FA2-C879-4921-9254-EDE3651AFCC7.jpeg 7BB79176-11C4-4D48-9DF1-6F4D214E000F.jpeg B309A029-418B-4F88-BFE8-69C08FC85120.jpeg 305D795D-C389-44DA-A4BB-7D52250D0A26.jpeg Yea man...
    Smokey15 and bodymanbill like this.
  3. gpm6367
    685
    28
    Feb 12, 2005
    New Joisey
    2C50792B-BEA2-4832-93C1-9E4253511057.jpeg CC61A2B1-61D4-44E1-A0DE-44235A79ED51.jpeg Love detail work. Something as simple as the trunk lid bumpers which were not removed and painted over when trunk was painted ala earl schieb. Remove, clean, recondition, reinstall. 15 minutes like new.
    Here’s a question: I know I should have a jacking instruction on underside of trunk lid. Most cars I have seen have posi decal on pass side and jacking instructions on drivers side. My posi decal on drivers side and has been there a while as it was masked off last paint job. I don’t know if it’s original. Any way to tell?
    Is there any rule of thumb? Can I just add a jack instruction to pass side?
    Feel free to post pics of known original trunk lid decals.
  4. gpm6367
    685
    28
    Feb 12, 2005
    New Joisey
    Ok I’m done with trunk for now. Used rust inhibitor on tire iron which had about 60% of its original paint. Blackens and preserves metal.
    D6262016-4C84-42F4-8FEB-74AA9EF7DA84.jpeg E8651720-59D0-49A0-8DC6-13498F500633.jpeg 9EDF4AF6-A200-4A7A-B6E7-828615D03342.jpeg E759E29D-C8AC-4590-AE5C-4D2F4D71E164.jpeg
    Just need to do something with that horrible wire connector on trunk light.
    Moving under hood and going to post questions in original drivetrain section.
    Please check out those threads. I have questions! :)
    Smokey15 likes this.
  5. COPO
    17,304
    510
    Toronto, Ontario, Canada
    The original Posi decal was made from paper and applied with black goo on the line and was on the pass side. It is avail as a repop. The shiny plastic posi decal is incorrect. BTW, not all 70 Z28's were installed with the rubber spoiler bumper that usually dented the qtr panel. Mine didn't and it was shipped to Canada if that made a diff. Maybe it was an item added after May since my Z is a May build date.
    My orig
    Repop
    gpm6367 likes this.
  6. gpm6367
    685
    28
    Feb 12, 2005
    New Joisey
    Gorgeous trunk. Thanks for info. I ordered them through Classic Industries.
    What adhesive do you use to glue posi warning?
    What’s the deal with the GM mark of excellence decals on doors?
    And who sells the blue decal with the VIN ? Does it go on drivers door?
  7. gpm6367
    685
    28
    Feb 12, 2005
    New Joisey
    You know I wasn’t done until I eliminated that hideous blue wire connector on trunk light wire. :) trunk is closed for first time in 10 days. 71368A1F-0A70-4AFD-868D-1BEF65B09EBC.jpeg
  8. bkmont
    bkmont Veteran Member
    1,112
    62
    Nov 14, 2010
    Pensacola, Florida
    ECS sells a good blue vin label. They will put your car's numbers on the label.
    I believe the 70 Camaro did not get a "Mark of Excellence" label. You will need a tire label for the drivers door.
    gpm6367 likes this.
  9. roeville
    roeville Veteran Member
    1,171
    67
    Oct 9, 2000
    SF East Bay CA
    Is this a picture of your trunk decal?
    BTW, it should say “limited slip differential” for 1970 and not “high traction differential”.
    gpm6367 likes this.
  10. 70lt1z28
    3,017
    532
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Tag is dated 3-16-71.
    gpm6367 likes this.
