About Gauge Marks
Discussion in 'Gauge Marks' started by 77RS, Feb 26, 2012.
  1. 77RS
    77RS Veteran Member NastyZ28 Sponsor NastyZ28 Sponsor Lifetime Gold Member
    2,940
    Oct 18, 2006
    Asheboro, NC
    The early tachs (70-77) use a D'Arsonval meter and a small tach circuit. These meters are slower and less responsive than the bi-coil meters used in 78-81 Camaro. Even though the early tachs are slower, there isn't an extreme amount of response time as you described. The problem with your tach could be in the meter itself, or a combination of the meter and tach circuit. There is no way to know for sure what the problem is without testing the tach myself. If you would like to send it in for testing I can give you an accurate quote for repair. Just let me know how you would like to proceed and I will be more than happy to send you the shipping address.
    Thanks!
    Daniel
  2. 2ndzcamaro
    2ndzcamaro Member
    34
    May 13, 2011
    hesperia ca
    tach ???
    Sorry for he slow response, I was wondering if it could be the filter and or grnd wire, it all seems to be intact, I will be in touch soon and thanks for the response, noticed your in N.C. I was born and raised in Greenville N,C, been stuck in C.A. for 30+ years, cant seem to get out of here LOLOL, again thanks.................... Garry
  3. 2nd gen man
    2nd gen man Veteran Member
    990
    Nov 28, 2010
    michigan
    Hello,
    could you please tell me how much the oil gauge is ?
    I want to install it in place of my clock.
    thanx.
  4. tmv36830
    tmv36830 Veteran Member Lifetime Gold Member
    332
    Jan 22, 2011
    Auburn, Alabama
    Daniel,
    If I send my guages could you redo them in reverse? White face and black numbers and add the oil pressure guage? PM me on the cost if this is an option.
    Thanks
  5. 77RS
    2,940
    Oct 18, 2006
    Asheboro, NC
    The oil pressure gauge for 2nd gen Camaro is an electric gauge that accurately registers 0-80 PSI when used with the correct sending unit. The sending unit can be purchased at the major auto supply stores (Advance, Auto Zone, NAPA, etc...) for about $20. The oil gauge will install directly into the clock mount location with no alteration. Instructions for wiring and sending unit information are included.
    The oil pressure gauge sells for $119.99 for 70-78 models; $129.99 for 79-81 models (A NOS plastic needle will be installed on the gauge for 79-81) If you provide a complete clock housing from any 70-81 Camaro as a core, the price will be reduced by $12. If your shipping address is anywhere in the USA, S&H is included. Paypal or USPS money order are the accepted form of payment.
    Thank you!
    Yes! The gauges can be painted white and have black markings at no additional charge. Pricing will vary depending on the work needed to be done. For example, if all of the gauges are working and are calibrated correctly, the cost will be less than if the gauges need repair and calibration. You can send in your gauges for testing and inspection so that I can give an accurate quote.
    Thanks!
    Daniel
  6. 77RS
    2,940
    Oct 18, 2006
    Asheboro, NC
    Click on this link to see gauges in white face. There are a couple of customers that have used the DIY packages to restore their own gauges with white face. Great work Chris and Laine!
  7. 2nd gen man
    990
    Nov 28, 2010
    michigan
    I will get back with you soon on the oil gauge kit.
    thanx. for your help
  8. 77RS
    2,940
    Oct 18, 2006
    Asheboro, NC
    No problem at all.Just let me know when you're ready.
    Thank you!
    Daniel
  9. ProchargedSS
    ProchargedSS New Member
    Jan 16, 2013
    Biloxi, MS
    Sent you a p.m.
  10. harbone66
    3,499
    286
    Feb 15, 2011
    Central Illinois
    Look up at post #20 for Laine's white face conversion.
    Here is my conversion with an oil psi gauge. The oil psi gauge was a black one that was in my old cluster. I just painted a new face (I used another complete cluster for the faces so I could still drive my car) and Daniel provided me with the black letters.
    [​IMG].
