AC blower motor fan switch
Discussion in 'Electrical Systems' started by 1st and goal, Jul 25, 2017.
  1. 1st and goal
    1st and goal Veteran Member
    400
    Nov 5, 2005
    Seacoast, NH
    I've recently lost high speed on my interior blower motor. I replaced the fan switch and also replaced the blower motor relay as I understood that to run high speed and the blower motor resistor ran low and medium speeds.
    The air still works, just on low and medium fan speeds. I replaced the blower motor a couple of years ago.
    What else am I missing?
  2. Gary S
    22,590
    810
    You are replacing the wrong parts. High speed runs through a separate wire and a relay. Check that circuit for a bad wire, bad connection, or bad relay.
  3. Twisted_Metal
    27,087
    1,012
    Check the big pink wire at the relay for power.
  4. budro6968
    budro6968 Veteran Member
    3,285
    528
    Apr 2, 2016
    Jax Florida
    I seem to remember an in line fuse inside a black insulated fuse holder for the high only. The wire is black too.
  5. twozs
    twozs Veteran Member
    8,817
    168
    Aug 5, 1999
    hopewell jct ny
    on my 73 its red and has a 30 amp fuse . It runs from the horn relay to the plug on the fan relay . It's the only fuse that not in the fuse box on the car .
  6. Scott51
    Scott51 Veteran Member
    625
    73
    Jan 2, 2012
    New Zealand
    Sounds like you're missing a circuit tester, :)
    start by checking the pink wire at the relay like Twisted said. If it's dead work backwards to the battery, (fuse, bad connection etc) if it's live, switch the heater to high and check power is coming out of the relay, if that's not doing anything check the trigger wire from switch to relay and relay ground and so on
    Just think of the wiring as a road going from point A (battery) to point B (blower motor) then it's just a simple process of elimination to find out where it's getting lost
  7. 1st and goal
    400
    Nov 5, 2005
    Seacoast, NH
    Thanks guys, sorry I forgot to post back in case anyone else has a similar issue.
    It ended up being a melted fuse holder so the relay was not getting any power. Replaced the fuse holder and am good to go.
