Aerospace components rear brake package
Discussion in 'Swap Meet Section' started by 383Camaro79, Feb 25, 2014.
  1. 383Camaro79
    383Camaro79 Veteran Member
    806
    Feb 11, 2000
    Alton, IL, U.S.
    Selling my Aerospace components rear brake package. 4 piston calipers, solid thin rotors. Rotor hats have holes for 5/8 studs in both 5x4 3/4 and 5 x 4.5 bolt pattern. Super lightweight setup. Used for a few hundred miles and a bunch of passes at the track.
    Was on a 9" ford but has the standard GM housing ends so same bolt pattern as your stock 10/12 bolt rear on the backing plates. $450 shipped obo
  2. ChevyReb
    3,775
    13
    Feb 4, 2003
    SC
    Will stock 15 inch wheels fit on this setup?
  3. 383Camaro79
    806
    Feb 11, 2000
    Alton, IL, U.S.
    The rotors are about only 11" diameter. I have ran several different 15" wheels all with no issues.
    However I dont own any stock wheels but I would assume you'd have no problems. Will stock wheels work with 5/8 drive studs?
  4. newschool72
    newschool72 Veteran Member
    1,185
    Feb 25, 2011
    forsyth,ga
    Can you run the stock diameter studs with the larger stud holes? Do they have an E-brake? Why are you getting rid of them? Trade for a 13" 4 piston rear setup?
  5. 383Camaro79
    806
    Feb 11, 2000
    Alton, IL, U.S.
    These are more of drag race type setup. They are extremely lightweight & thin non vented rotors. They do not have any e-brake. I suppose you could still use them with smaller lugs since they will be sandwitched in place by the wheel.
    No trades. I have already switched over to a dual caliper setup with a vented rotor.
  6. newschool72
    1,185
    Feb 25, 2011
    forsyth,ga
    Gotcha. Im kinda flipping the idea around of getting my car capable of running a 15" wheel and a tire with a sidewall, for the track trips. My 13" setup is too big and I cant seem to hook with the 17s. GLWS!
  7. ChevyReb
    3,775
    13
    Feb 4, 2003
    SC
    Yea I'm out too thanks.
