AF ratio gauge
Discussion in 'High Performance Modifications' started by Bbcngineer, Nov 8, 2019.
  1. Patrick73RS
    Patrick73RS Veteran Member Lifetime Gold Member
    1,661
    58
    Oct 1, 2004
    Montreal (Living in Houston)
    I bought Dual AEDs in my 71. DM me your email and ill send you a video
  2. ULTM8Z
    ULTM8Z Veteran Member
    9,189
    355
    May 19, 2000
    Los Angeles
    Ditto
  3. Coadster32
    1,684
    137
    Oct 2, 2013
    Milford,CT
    I also have an AEM. I'll echo what was said about compromise, and fuel injection. If you have OCD, and want to get a carb running perfect everywhere through the pedal....it will beat you up. Especially if you have a bit of a cam in it.
  4. nobreaks254
    nobreaks254 Veteran Member
    495
    9
    Jul 14, 2007
    aberdeen, SD
    I have a couple of the aem units. Very happy with them
  5. Jeep43
    Jeep43 Veteran Member
    1,305
    48
    Mar 30, 1999
    Connecticut
    Agree. Especially idle mixture. I try to ignore the gauge when setting idle mixture and use a vacuum gauge instead. It reads rich on the meter when set that way but the car doesn't like it any leaner.
    I do use the meter to adjust WOT and cruise (between 14 & 14.5).
    jeff swisher likes this.
