AFR 383 dyno numbers?
Discussion in 'High Performance Modifications' started by CamaroMan79, Jul 20, 2011.
  1. CamaroMan79
    CamaroMan79 Veteran Member Lifetime Gold Member
    5,204
    10
    Jun 10, 2001
    Selah, WA
    Im looking for dyno numbers for people running an AFR headed 383 (perferably the 195cc)
    Im just trying to get an idea what my combo might put out.
    My specs are:
    383
    10:1 compression
    1 3/4" headers
    AFR 195 heads
    .510/.520 lift roller cam
    RPM Air-Gap intake
    770 carb
    Mallory HEI
    timing is 20 initial and 37 total all in by 2800rpm
  2. 79RedZ
    79RedZ Veteran Member
    670
    34
    Mar 24, 2009
    Hamilton,MI
    I saw the dyno sheets on one 383 setup very similar to yours and it was at 520 hp. The compression on that was 10.3 and the lift was .525 on both sides I do believe it had 1.6 rockers on it. Same intake and a pro-systems 750 carb.
  3. 1971zed
    1971zed Veteran Member Lifetime Gold Member
    289
    16
    Aug 31, 2010
    Retired in Ottawa Canada
    383 SBC stroker, 425hp/440tq @ the flywheel
    AFR SBC 195 aluminum cylinder heads, 74cc, straight plug
    Eagle 4340 crank, 3.750" stroke
    Eagle 4340 H-beam connecting rods
    Holley 650HP-based carb prepped by Bo Laws (BLP), Weekend Warrior
    Edelbrock Performer intake manifold, dual-plane, aluminum #2101
    ATI Super Damper 6.325" balancer
    SRP forged pistons, flat top
    Moroso 7 qt oil pan
    Moroso HV oil pump (w/ ARP oil pump driveshaft)
    Moroso oil pump pickup
    Stewart Stage 2 aluminum water pump, long
    Carter mechanical fuel pump, aluminum, 120 gph
    Comp Cams Xtreme Energy XE268H camshaft, hydraulic flat tappet
    Comp Cams High Energy hydraulic lifters
    Cloyes True Roller timing set
    Comp Cams Hi-Tech pushrods, 0.100" long
    MSD Street Pro-Billet distributor w/ vacuum advance
    MSD Digital 6-plus ignition
    MSD Blaster SS coil
    hubedobeedo likes this.
  4. ProStreet383
    ProStreet383 Veteran Member
    2,106
    9
    May 23, 2007
    MD
    You serious? Doesn't sound right to me. If that's correct it sounds as if you need a cam change. With those big 74cc heads what is your compression ratio? I would expect no less than 480+ crank hp out of an AFR headed 383 and 10:1 to 11:1 compression with the proper cam.
  5. Led Zep
    Led Zep Veteran Member
    542
    11
    Mar 13, 2008
    Ky
    383
    10.6 CR
    AFR 195
    Comp XR294
    Race Weight 3000 lbs
    3.90 gear
    105 MPH 1/8 mile
    132 MPH 1/4 mile
    I would guess a honest 500 HP.
  6. 1971zed
    289
    16
    Aug 31, 2010
    Unfortunately I didn't build the motor. I did see the dyno printout and I did see the build sheet the previous owner had from the engine builder.
    I was told the CR was 10:1
    If I do get a chance to put it on a chassis dyno I'll see if it's true :)
    If I get around to mounting a set of ET Drag Radials, I plan to get to the track to see what it will run.
    As it is now I won't waste my time going to the track...I have no traction at all with my current tires.
  7. DesmoEd
    DesmoEd Veteran Member
    1,137
    Sep 9, 2009
    Frisco, TX
    Small cam and carb. Those heads are nowhere near their potential
    If CR and quench is correct adding a hyd roller .550 lift / 230-240 @ .050 with a 750HP and you would have 480hp/520tq
  8. ProStreet383
    2,106
    9
    May 23, 2007
    MD
    Yup that is exactly what I was thinking. Little more cam than that and he would be touching 500hp.
  9. ProStreet383
    2,106
    9
    May 23, 2007
    MD
    Good luck with it! If it ends up not running what you want it will be pretty easy to tap some more power out of it with a cam change and the proper carb. :bowtie:
  10. 80 Z28
    80 Z28 Veteran Member
    1,205
    Mar 25, 2000
    Regina, Saskatchewan, Canada
    What do you guys think this combo will have?
    406ci
    13:1
    AFR 195
    850 Holley
    Comp 292H with 1.5 rockers
    Air Gap
    Stock HEI
    Stock bottom
