Aftermarket Valve Covers - LS Swap - Brake Booster Clearance
Discussion in 'High Tech Retrofits' started by Dcmusch, Feb 10, 2020.
  1. Dcmusch
    Dcmusch New Member
    27
    Aug 21, 2014
    San Antonio, tx
    I bought some of the Holley 2 piece valve covers and went to install them but they wouldn't fit because of the brake booster. Has anyone had had this problem and if so what valve covers did you go with. If they are the style that the coils mount directly to the valve covers did you have to upgrade the coils and get a different wiring harness. Parts and pics would be appreciated. Thanks in advance, I need to order these so I can get the motor running.
  2. Goat
    1,908
    44
    Jun 7, 2001
    moncure, NC
    That area is tight especially with the 1" set back of the DSE subframe. I am using the stock valve covers and had to modify the coil bracket on # 7 because the booster was interfering. And that is with a 7" booster a bought in anticipation of this problem. I am also using aftermarket coils/bracketry that may be different than stock...
  3. badazz81z28
    17,094
    546
    Las Vegas, NV
    1CE30A71-83EA-4246-8D67-AE2B9E5C196E.jpeg C6657756-B9F1-437D-B499-2986A530A6AC.jpeg 729C34B0-A18C-4D37-B56B-FDD43513A975.jpeg I run the DSE frame and the DSE booster and MC. Same issue as you, the 2 piece LS covers do fit. However, you can’t install one of the bolts. It would require you to remove the booster to install it making the set-up not able to be serviced. I resorted back to normal OEM covers and no mods required. I ended up sending my Holley covers back regardless because the baffles were poorly secured. D53ABD4D-7E2A-4989-BAB1-954B5854EC54.jpeg
