All gauges out.
Discussion in 'Electrical Systems' started by Lizzard323, Nov 8, 2019 at 1:46 PM.
  1. Lizzard323
    Lizzard323 New Member
    Jul 31, 2019
    81 Z28. All gauges out. I see a “circuit board” panel from Ricks. Think that will fix em?
  2. CorkyE
    10,265
    430
    Assuming you mean the gauges are not working as opposed to out of the car? Have you checked the fuse block? Should be a 10A fuse labeled Gauges.
  3. grzewnicki
    3,330
    118
    Dec 9, 2009
    Gordon from Jacksonville Fl
    Don't start throwing money at things till you have done some work seeing if it is something as simple as a fuse. If you are gonna own an old car you're gonna have to get familiar with wiring diagrams. If you have no idea how to read them people on here will help you out and of course YouTube or googling how to read electrical diagrams is always a good idea. Just like a road map, you're a guy, you can read a map right? LOL. Two best tools you can invest in are a good quality test light, with a good alligator clip on it so you can attach it to lots of things for a ground point and VOM, Volt Ohm meter, good to have one with an audible setting so when checking continuity of wires you'll hear a beep and not have to look at the meter. Lets us know what you find after checking the fuse....
