Allright, who's running beehive valvesprings?
Discussion in 'High Performance Modifications' started by kimosabi, Jun 20, 2015.
  1. kimosabi
    kimosabi Veteran Member
    754
    Oct 7, 2013
    Not
    Got the PAC 1215 springs set for my AFR 210 heads. Hyd roller deal. Waiting for seats to set install height.
    Found very little info on these beehives online, seems to be some internet concerns that if they break, you don't have a chance.
    If a dual or triple breaks you still have a chance to pull over and stop before $hit hits the fan/valve hits piston.
    Your thoughts?
    :bowtie:
  2. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    Would not worry about it. They are very reliable. Excellent spring.
  3. kimosabi
    754
    Oct 7, 2013
    Not
    Yeah I'm not worried, just curious if anyone has actually seen one break. The cam I'm getting is pretty mild with a hyd roller 232/232 @0.050, .36/.353 lobe.
  4. Dogwater
    Dogwater Veteran Member
    926
    Dec 23, 2010
    SanAntonio Tx
    Go to hotroders.com there's a boatload of info on beehive springs. You'll have to become a member to use the search function, but there's an hour worth of reading.
  5. DFWJ
    DFWJ Veteran Member
    300
    Aug 16, 2012
    DFW
    Beehives are great, those springs will handle more cam if you wanted
  6. Lowend
    14,933
    430
    Mar 25, 1999
    San Jose, CA, USA
    There were some issues with the ones Chevy used on the LS6 early on, but those have long since been solved
  7. Rockhound
    Rockhound Veteran Member
    158
    Dec 3, 2007
    tennessee
    I used some years ago and have no complaints. Worked as advertised.
  8. kimosabi
    754
    Oct 7, 2013
    Not
    In my internet search for anything bad, breakage or whatever I came across a posting about that on some Corvetteforum, then GM replaced all springs IIRC.
    Yeah, I'm confident, just curious where the word of mouth worry stems from. Probably that GM recall years ago.
  9. Tokyo Torquer3
    Tokyo Torquer3 Veteran Member
    2,187
    Oct 14, 2003
    NJ
    I wouldn't run a beehive unless it were a PAC spring. PAC is fantastic quality.. bar none. I have used PAC beehives before. Not sure how much of an improvement they made, but they held up fine.
  10. kimosabi
    754
    Oct 7, 2013
    Not
    Springs are Trick Flow TFS-16915, which are rebranded PAC 1215.
