alternative fuel pick-up for EFI
Discussion in 'High Tech Retrofits' started by newschool72, Mar 20, 2012.
  1. nbet
    nbet New Member
    14
    Nov 23, 2012
    Washington
    Tank sealant
    Man I'm ready to do this, have dropped the tank again on my 68 Firebird w/Edelbrock EFI, which is starving on too many hills and turns. But I found that the hole is only about 1.75" dia. Too small to fit the Walbro pickup through right? So, I guess that means I have to cut open the tank. What's a good gas-proof sealant for sealing up the lid on the cutout and any other tips for doing things that way?
  2. Fbird
    4,311
    763
    Feb 12, 2011
    atlanta, ga
  3. newschool72
    newschool72 Veteran Member
    1,185
    Feb 25, 2011
    forsyth,ga
    Update on mine. I started having issues with hard starts. I took the system down and found a tear in one of the small pieces of rubber hose. I assume it was loosing prime. I also had an issue with lost fuel pressure and a very loud external pump.
    My fix was to completely start over. I got an Aeromotive HP700 submersable pump and installed it the same style as the FORMER walbro pickups. I then built a line and sock on the pickup side of the pump and built a tray with high inward sloping sides w 6 drilled holes in the bottom( located so they are open to the open areas on the ribbing at the bottom of the tank). I then ran my return into tray on the opposite side to reduce areation. My supply to the engine comes out the front of the tank just below the center seam.
    I got away from the walbros because the submersable hose failed, not because the pickups didnt work. I didnt want to risk having to take the tank apart again because a 2" piece of hose failed.
    So far the new system is doing great, but I havent pushed it hard yet. I will update when I do test it with anger.:)
  4. nbet
    nbet New Member
    14
    Nov 23, 2012
    Washington
    Thanks for the update. It helped push me in a different direction. Just bought a Tanks, Inc. EFI replacement tank and GPA-4 internal pump.
  5. Sode
    Sode Member
    66
    Jan 15, 2010
    I went down to put the contraption in the tank, and the pickups don't fit through the hole! Well that was a big waste of money as the main reason I did this was so I wouldn't have to cut the tank open. What a bummer. For future reference for others, my tank is a '78
  6. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    That sucks. Other than the low fuel starvation the 70 in a 78 is working fine.
    I am tempted to drop the tank and redo the Spectra baffle, but the hesitation
    is a nice warning that its low on fuel .. kinda like a light but with more "weight".;)
    Tom
