Aluminum radiators
Discussion in 'High Performance Modifications' started by muscl car, May 8, 2019.
  1. muscl car
    21,726
    638
    Jul 8, 2001
    High Desert of Hesperia Calif
    Looking at aluminum radiators and notice there's 2 and 3 row radiators available . Is there better cooling with a 3 row ???? . I've heard that a 2 row is sufficient enough is this true ?????
  2. frankz
    frankz Veteran Member
    2,090
    13
    Aug 24, 2009
    Illinois
    2 row should be fine if it has big tubes
    hubedobeedo and muscl car like this.
  3. Evil Twin
    Evil Twin Veteran Member
    178
    31
    Jul 10, 2018
    Lake Havasu, AZ
    What I can tell you is you wouldn't catch me buying into that with my Firebird.
  4. wnmech
    wnmech Veteran Member
    938
    82
    Jul 20, 2014
    grand prairie tx.
    I bought a3 row aluminum radiator for my 71 and it cools great in the Texas summers with my VA system
    hubedobeedo likes this.
  5. muscl car
    21,726
    638
    Jul 8, 2001
    Ordered a Griffin radiator #8000-10 two row with 1.25 tubes
    76z28 likes this.
  6. 1980RS
    1980RS Veteran Member
    3,418
    597
    Jun 17, 2006
    MN
    Take a look at the factory stuff, either 1 or 2 rows and newer stuff cools great compared to our old cars.
  7. jeff swisher
    jeff swisher Veteran Member
    1,375
    416
    Apr 26, 2018
    Yukon Oklahoma
    You must look at the low drag these new engines have.
    My old school Loose built SBC has to have 45 lb of TQ to break over the engine to get it to turn.
    The LS is closer to 20 lb.
    Short skirts thin rings.. and lots of oil usage :)
    I had to toss that in there.
    2 rows of 1" tubes is what I have and only a 19x22" radiator..that includes tanks!
    400+ Hp no issues with old school long skirt thick ring engine.
    Now there are many issues with some 3 row radiators as they are not all made the same.
    Core spacing could result in less cores and core width some import 3 row aluminum radaitors can have very small cores like .62" wide.. the 2 core would trump it with 1" wide cores.
    Do your research.
  8. 76z28
    76z28 Veteran Member
    2,051
    51
    Jun 29, 2009
    bakersfield
    I've been researching that too. It should have more surface area than the brass radiator since those are generally 3/8 inch wide which would total 12/8 or 1 and 1/2 inches(for a cheap 4 core it would be around 2 to 2.5 inchesif it were a more expensive I set up)
    This is a good read. I'm looking to get the griffin 1.5 inch tubes
    https://www.speedcooling.com/blog/category/radiators/3-row
  9. 76z28
    2,051
    51
    Jun 29, 2009
    bakersfield
    All I can find is the 1.25 two core so u might go with that
    muscl car likes this.
  10. 76z28
    2,051
    51
    Jun 29, 2009
    bakersfield
    Let me know how this works for you @muscl car I am looking to order the same. I am currently running a factory shroud and a clutch fan so I am hopeful I can continue using those, but may look into swapping to an LT1 style fan set up if needed.
    And can you take pictures of the core innards? I am curious as to how they look compared to my 4 core.
    I really would like to continue using my clutch fan/shroud
