Aluminum radiators
Discussion in 'High Performance Modifications' started by muscl car, May 8, 2019.
  1. badazz81z28
    16,991
    522
    Las Vegas, NV
    Correct the size is more important than the # of rows.
    I’m pretty sure my Dewitt is a 2 pass and so is the C&R im looking at
  2. 76z28
    76z28 Veteran Member
    2,051
    51
    Jun 29, 2009
    bakersfield
    Correct size of what?
    You want the biggest rows you can stuff in there. I wouldn't mind a two pass, but in reality a single pass radiator with 2 1.25 inch rows will out cool my current car quest made in China 4 row(with I believe 3/8 inch rows) radiator. While it's adequate, I want the extra capacity as I feel if mine ever starts to clog(even though I change the coolant yearly) it won't be enough.
    Looking at the size
    Brass: 3/8 x 4 would be 1.5 inches
    Aluminum: 1.25 x 2 would be 2.5. Inches per each tube.
    That's a LOT more surface area for sure. Just a ROUGH guess in the surface area let alone the better fin/tune spacing would be:
    Assume the core itself is 23 inches wide....
    23 x1 is 23 sq inches per row.
    Now assume there are 40 rows(on the lowside) 23 Sq inches x 40 would be 920 Sq inches more surface area.
    Aluminum total: (2.5x 23) x 40=2300
    Brass total: (1.5 x 23) x 40=1380
    That's 60 percent more surface area assuming a 2 dimensional figure (again rough math) this
    Edit:yes I know surface area is not everything, but we can know that it makes a large difference here.
  3. 76z28
    2,051
    51
    Jun 29, 2009
    bakersfield
    Any pictures/reviews of this?
  4. DesmoEd
    DesmoEd Veteran Member
    1,144
    9
    Sep 9, 2009
    Frisco, TX
    I'm been running one of these for the past 8+ years
    http://www.entropyrad.com/1970-1981...or-with-dual-hp-fans-and-aluminum-shroud.html
    I paid around $500 for it back then and can affirm its an absolute beast. I've had the car sitting in the drive thru for 20 minutes with the a/c on in 100 degree Texas heat and it runs a cool 190-195 degrees.
    I think the fans make all the difference, after having elec fans on both cars I'd never go back to a mechanical fan and shroud setup
  5. muscl car
    21,744
    661
    Jul 8, 2001
    High Desert of Hesperia Calif
    I'll try and take pics when I get home tonight !!!
    This website is hit or miss trying to log on here. , I'm lucky just now was able to !!!
    76z28 likes this.
  6. 76z28
    2,051
    51
    Jun 29, 2009
    bakersfield
    Awesome, I am excited to see!
  7. muscl car
    21,744
    661
    Jul 8, 2001
    Here you go !!!!! :)
    76z28 likes this.
  8. 76z28
    2,051
    51
    Jun 29, 2009
    bakersfield
    Interesting that doesn't look as wide as what's in my car right now!
    Do you know the dimensions? I'm curious as to how thick it is and how wide/tall it is. Now I need to go measure mine
    muscl car likes this.
  9. 76z28
    2,051
    51
    Jun 29, 2009
    bakersfield
    I will say that thing does look nice
  10. muscl car
    21,744
    661
    Jul 8, 2001
    Overall Width (in):31.250 in.
    Overall Height (in):18.620 in.
    Overall Thickness (in):3.000 in.
    dcozzi and 76z28 like this.
