Alumunium rims & Lug nuts
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 1981zapper, Sep 12, 2019.
  1. 1981zapper
    1981zapper Veteran Member
    1,368
    Apr 28, 2009
    Southern Ontario, Canada
    I bought a set of American Racing 200S aluminum rims and installed new lugs nuts, I noticed the lug nut galled the rim seat,
    Is it a good idea if I put some grease or anti-seize on the lug nut tapper?
    the rim uses a 60 degree Conical seat
  2. Twisted_Metal
    26,818
    875
    Odd that it did that. :(
    I don't see any reason why you can't put a little grease on the tapered part of the lug to prevent more galling.
  3. badazz81z28
    16,308
    394
    Las Vegas, NV
    I put anti seize on mine.
  4. flht99b
    flht99b Veteran Member
    133
    19
    Nov 28, 2014
    Knoxville, TN
    Do your lug nuts take a 3/4" or 13/16" socket? I've seen this galling with 60 degree 13/16" lug nuts.
  5. 1981zapper
    1,368
    Apr 28, 2009
    3/4" socket,
  6. Knuckle Dragger
    14,552
    1,183
    Nov 2, 2002
    Waddell AZ
    Any lubricant applied will alter the torque specs.
    This explains it well.
  7. Twisted_Metal
    26,818
    875
    Won’t galling also alter the torque specs?
  8. 1981zapper
    1,368
    Apr 28, 2009
    I won't be applying any anti-seize on the studs just the "seat"
  9. Knuckle Dragger
    14,552
    1,183
    Nov 2, 2002
    Waddell AZ
    It will still have some effect on the torque. I'm not saying do it or don't do it, just trying to advise caution about over torquing them if you do. Obviously something has to be done due to the issue. I'm not sure how many of us use a torque wrench on wheels anyway. At my job, not applying lube when you're supposed to or vise versa would be a write up or possibly time off, they don't play at all on the policy.
  10. cadillac_al
    cadillac_al Veteran Member
    808
    75
    Apr 22, 2015
    Maine
    I was worried about affecting the torque rating too but after seeing that excellent video I better understand why. Those lugnuts and seats may/should mate together eventually and stop galling. Aren't 200S those awesome hippie daisy wheels? I love those wheels. You'll have to show us a pic of them installed.
