Amp gauge wiring? (U14)
Discussion in 'Electrical Systems' started by Dave Nelson, Sep 22, 2009.
  1. Dave Nelson
    3,817
    1,190
    Dec 19, 2003
    Vineland N.J USA
    I removed my U14 gauge cluster to do some work on my gauges, and also see why my amp gauge does not operate. I found the original plug missing from the amp gauge, and in it's place were 2 spade terminals, 1 was going to a ground {not original] and the other going into the harness (dark brown). The car is a 1970.Does anyone have a pic of the original plug so I can see what color the wires are , also maybe a wiring diagram as I found nothing shown in the assembly manual.
    Thanks Dave
  2. ezcruisn71
    ezcruisn71 Veteran Member
    239
    Jun 2, 2006
    SE, Michigan
  3. Dave Nelson
    3,817
    1,190
    Dec 19, 2003
    Vineland N.J USA
    Rick, the wires that I am looking for do not go into that connector. They go into the engine compartment. I need to see a pic of the plug on the amp gauge to idenify the colors.
    Thanks Dave
  4. ezcruisn71
    239
    Jun 2, 2006
    SE, Michigan
  5. Z20AINT
    Z20AINT Veteran Member
    630
    May 29, 2007
    Minnesota
    One wire goes to the horn relay / alternator. The other wire goes to the starter solenoid. The amp gauge really measures the voltage drop between the alternator and the battery. Kinda worthless in my opinion. Dump it for a voltage gauge.
  6. Orange71
    Orange71 Veteran Member Lifetime Gold Member
    3,792
    Jan 31, 2001
    Finksburg, MD
  7. Cardinal
    8,249
    16
    Jun 22, 2003
    Endicott, NY
    Be VERY careful with amp gauges as I've seen some awful electrical fires caused by them. A volt gauge is much safer in the long run.
  8. Gary S
    21,531
    427
    The factory amp gauge isn't a true amp meter. It is a low voltage voltmeter instead that measures the difference in voltage between the two points mentioned above. You don't have to worry about it anymore than you would worry about the meter marked volts.
  9. Dave Nelson
    3,817
    1,190
    Dec 19, 2003
    Vineland N.J USA
    Thanks for the replys fellas, I didn't think there should be a ground wire on one side of the gauge as I found it. Now to see if the gauge is still good, and trace the correct wires, if I can locate them.
  10. tom3
    tom3 Veteran Member
    11,313
    189
    Aug 1, 1999
    ohio
    Two wire plug with a black and a black/white stripe wire. Complicated setup for this in the 70. I think the gauges lose their sensitivity over time and quit working even when wired correctly. I finally gave up and put a volt gauge on my 70. If your gauge has been hooked up wrong it's probably toast.
