AN fitting on a stock fuel pump
Discussion in 'Engine Topic' started by cutty, Mar 3, 2012.
  1. cutty
    cutty Veteran Member
    342
    Dec 12, 2008
    ontario canada
    does anyone know if a AN fitting will fit a stock Mechanical fuel pump, if so
    what size??
  2. muscl car
    21,807
    701
    Jul 8, 2001
    High Desert of Hesperia Calif
    if you're looking for a AN fitting such as a AN flare to pipe fitting for your pump then it would be a 1/4" dia pipe fitting and you can easily use a #6AN hose to feed your pump so it would be a #6 AN flare to 1/4" pipe fitting you're looking for
  3. cutty
    342
    Dec 12, 2008
    ontario canada
    i got the -6 but was 3/8's which didnt fit, thanks for the help
  4. Orange71
    Orange71 Veteran Member Lifetime Gold Member
    3,792
    Jan 31, 2001
    Finksburg, MD
  5. camcojb
    camcojb Veteran Member Lifetime Gold Member
    2,599
    Jan 10, 2000
    Wilton, Ca. USA
    many if not most stock pumps I've seen are inverted flare fittings, not pipe thread. The aftermarket pumps like Edelbrock and Holley use the pipe threads.
  6. swerven
    swerven Veteran Member
    101
    Mar 11, 2009
    Gone
