another cam question
Discussion in 'High Performance Modifications' started by br80z, Jul 19, 2005.
  1. br80z
    br80z Veteran Member
    508
    Apr 6, 2001
    Fuquay Varina, NC
    Here is the combo that I had before I striped my car down to the frame.
    350 flattop pistons
    Performer Intake
    Holley 600vac sec
    Stock 882 heads about 8.5compression
    Headers, dual exhaust
    TH350 trans with stock converter
    3.42 rear end
    Blue Racer Cam 1103 duration at .05 204I 214E lift .420I .442E
    Overall this has been a good combination for a street car, but now that I'm converting the car to a 4 speed I would like a little more power and RPMs.
    The tech guy at Lunati recommended the voodoo 60102, but the voodoo +springs + lifters, is just out of my budget.
    In the competition products catalog I found a kit with an Elgin cam, lifters, and z28 springs that I can afford.
    Elgin cam E1166 duration at 05 216I 228E Lift .453I 480E Lobe Center 112
    Would this be a good choice for a weekend streetcar?
    1998 Camaro - Daily Driver
    1980 Z28 - Much assembly required!
  2. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    Please consider a Summit one step over the one you have!
    The 214/224 cam.
    I mention it b/c you said you are KINDA bucks down is all.. AND I figure less than a "C-Note" is good valve for a cam and lifters..
    I wouldn't go any bigger b/c of your 8.5 CR!!
    ANd I figure a CC 260HE about right, imho.... What's it $119 or so from Summit less lifters???
    ANd you might try Delta if you want to furnish a core and get onna their regrinds..
    Really down the line in price to me...
    AND don't get me wrong, b/c Harold's/Lunati's VooDoo line is GREAT, although rather pricey..
    pdq67
  3. Mwilson
    Mwilson Veteran Member
    i would consider the comp 280H?
    You are low on compression and need different heads though.
