Another rim thread 16 front 18 rear?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by NickRoy, Aug 9, 2019.
  1. NickRoy
    NickRoy New Member
    Jun 30, 2019
    8BB7E226-D631-4EF7-B5B8-E7EE31FC4BC0.png 4AAE496C-9A2C-405B-ACEF-E45363774286.jpeg Hey guys looking for new rims for my car as it just got finished and the old 15s are a little small in the rear. There’s a nice set of ion 161 rims for sale but they are 205/55/16 fronts by 8 wide 4 inch bs,and 235/60/18 rears 9 wide with a 5inch bs. Would they look bad being so far apart in rims size I can’t find any 16/18 combos or if you have any input on rims or size any help is appreciated here is the car and rims.
  2. 79T/Aman
    79T/Aman Veteran Member NastyZ28 Sponsor NazstyZ28 Sponsor Lifetime Gold Member
    2,436
    123
    Oct 7, 2004
    Dickson TN.
    that is for a street rod, find 17s or 18s front and rear and you can go wider than that.
  3. NickRoy
    NickRoy New Member
    Jun 30, 2019
    Thank you so I’ll stay away from them, what’s the widest I can go? I would prefer not to roll my lip as it just got painted less than a month ago.
  4. SPG
    SPG Bumblebee Builder
    263
    32
    Sep 1, 2018
    Sacramento
    you can go about 10" wide in the back depending on how big the tire is, some configurations will rub, others won't.
    I have pretty thick tires on 15" rims so they would have rubbed. Previous owner cut the fender instead of rolling it though (which I did not realize until much later) This could have been avoided if you didn't use lowering blocks on the car.
    my rear has 275/60/15 tires
  5. nobreaks254
    nobreaks254 Veteran Member
    489
    8
    Jul 14, 2007
    aberdeen, SD
    275 is the simplest in the rear. You can go wider but you may or may not have rubbing. Depending on wheel backspace.
  6. Coadster32
    1,581
    120
    Oct 2, 2013
    Milford,CT
    I run 275/60 R15 in the rear also. My local tire place said that's about where I want to be w/o modifications, or a different rim.
  7. QUAKE_WARS
    QUAKE_WARS Veteran Member
    1,869
    101
    Dec 19, 2008
    you can run 17x11 with 315/35 in the rear and 17 9 1/2 up front with 275/40
    Do a search, all the info is here.
  8. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,342
    78
    Feb 2, 2008
    SF
    1D32AA94-6758-4065-990D-A9C8DBAC986F.jpeg 303B7B5B-7B59-46C6-9681-C3A82A8C1DA2.jpeg The widest I can go on my first gen Was 10 inch wheel with 285 tire
    For your car I would go with a
    18x8 front with a 245/40/18
    18x9 with a 275/35/18
    I have that combo on my camaro and plan to put those on my 73 firebird soon
    When I paint the star
