Anti Seize for plugs
Discussion in 'Engine Topic' started by earnhardtgm3, Mar 24, 2014.
  1. earnhardtgm3
    earnhardtgm3 Veteran Member
    3,133
    38
    Dec 18, 2007
    Camaro Country,GA
    Do you use anti-seize for the spark plugs on aluminum heads?If so,what is best to use?
  2. fbody_mike
    fbody_mike Veteran Member
    972
    Mar 24, 2009
    San Gabriel Valley, California
    I only put anti-seize when they are long life platinum plugs, otherwise they go in raw. Been doing it this way for decades on motorcycles without a problem. My GM v6s that have 100K miles plugs always get anti-seize. I just get whatever copper stuff they have on the shelf.
  3. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,063
    Sep 22, 2007
    Blind Bay, B.C.
    I got this from an electrician at work for use on aluminium wire, I use it on my plugs too, seems to work really well...Penetrox A-13.
  4. RS1979
    3,755
    748
    Jun 18, 2013
    Memphis, TN
    I don't have aluminum heads yet; but, I've always used Permatex Anti-Seize on my plugs. Never a problem.
  5. COPO
    17,855
    748
    You better be using it or you'll have a problem getting the plug out and hope you don't have heads like some Ford heads with hardly any threads or you'll be Helicoiling them.
  6. CorkyE
    10,375
    470
    I've always used it on spark plugs in aluminum heads. Use it sparingly though, it's conductive and if you get too much on the threads it will seep out and cause a dead short. Had someone do this to my Mother's mower once, took me a bit to find out what was causing the miss.
  7. Rene Melten
    4,063
    Sep 22, 2007
    Blind Bay, B.C.
    Yep, since the threads are tapered, no need the apply it to the first two threads. A little dab will do.
  8. 1981zapper
    1981zapper Veteran Member
    1,385
    Apr 28, 2009
    Southern Ontario, Canada
  9. kain13
    kain13 Veteran Member
    519
    Jul 6, 2006
    Lubbock,Texas
    had one stick, i use it on every thing in aluminum
  10. COPO
    17,855
    748
