Any chance this cam will have enough vacuum for brake booster?
Discussion in 'High Performance Modifications' started by DENALI, May 2, 2019.
  1. DENALI
    DENALI Veteran Member
    1,096
    19
    Nov 4, 1999
    Sonova Beach
    .......or should i plan on going to manual brakes? I was hoping to use a twin diaphragm unit off a Turbo TA disk setup if possible. THanks
  2. jeff swisher
    jeff swisher Veteran Member
    1,461
    441
    Apr 26, 2018
    Yukon Oklahoma
    238-248 @ .050 does not look all that huge to me as far as killing engine vacuum to the point that power brakes do not work.
    But there are other factors that need to be looked at like huge rectangular port heads vs some bowl ported 781 oval heads.
    The size of the runners and velocity through the runners will be a big factor as will engine displacement.
  3. DENALI
    1,096
    19
    Nov 4, 1999
    Sonova Beach
    .030 over 454, 10:1 compression, fully ported and polished 049 oval port heads.
  4. 1980RS
    1980RS Veteran Member
    3,553
    650
    Jun 17, 2006
    MN
    Hard to say on that cam. The LCA is kinda tight for power brakes, put it on a 114° LCA and you will have more vacuum.
  5. jeff swisher
    1,461
    441
    Apr 26, 2018
    Yukon Oklahoma
    I had a 350" chevy and had 2 cams ground 218@ .050 the old 268H grind.. one on a 106LSA and the other was ground with the same intake closing point to keep cranking pressures the same and the dynamic compression would also be the same but cam #2 was ground on a 112LSA by moving exhaust lobe only.
    2" difference in idle vacuum.
    You will be fine with your cube and the what I consider small duration cam.
    I also ran a 235-245 on a 108LSA in a 355" and it had plenty of vacuum.
    I know small engine.
    I have seen bigger in the BBC 396" and still had enough vacuum
  6. CorkyE
    10,453
    508
    Do you already have that cam? The 106 lsa will be your limiting factor. One option is to use a vacuum reserve canister, I've had one for years.
  7. DENALI
    1,096
    19
    Nov 4, 1999
    Sonova Beach
    Yes already have it. Just putting the car together now after 3 years of no time to do it.
  8. COPO
    18,065
    870
    I can get 11-12" of idle vacuum with my roller cam with 10.2 cr.
    • Advertised Duration (Int/Exh): 278/288
    • Duration @ .050 (Int/Exh): 232/242
    • Gross Valve Lift (Int/Exh): .507/.507
    • LSA/ICL: 112/108
  9. 450bench
    450bench Veteran Member
    3,149
    44
    Feb 25, 2002
    memphis, tn-shelby
    I'd bet you'd be fine with that cam
