Any way to replace press in studs?
Discussion in 'Engine Topic' started by 1979rallysport, Sep 21, 2009.
  1. 1979rallysport
    1979rallysport R.I.P 4/1/16 Gold Member
    566
    Mar 18, 2009
    Bay City, Michigan
    Is there anyway I can replace a press in rocker arm stud myself? I really dont want to have a machine shop do it, just because the heads are already on and the motor is put back in the car.:(
  2. Simon@London
    Simon@London Veteran Member
    1,244
    Feb 16, 2009
    London Ontario
    There is a tool out there for this, I thought I saw one on Jegs sight before.
    7/16 Tap
    Doing it with heads on Car will be real risky if any metal falls into motor or down oil galley. A magnet surrounded by grease to catch stuff will be a must.
  3. 79camaro2001
    4,759
    May 4, 2003
    Monroeville, PA
    That head will have to come off.
    Kind of hard to get a press in the engine bay. Also if one has pulled out, then the other's might be on their way. I would either pin the rocker studs in place or have screw-in studs installed.
  4. 1979rallysport
    566
    Mar 18, 2009
    Bay City, Michigan
    Im pulling the head off the motor, my question is, is there a way to remove the old stud ( threads are stripped off).
  5. 1979rallysport
    566
    Mar 18, 2009
    Bay City, Michigan
    Head is coming off, the old one didnt come out, just has stripped threads.
  6. FatnLow
    1,951
    Mar 12, 2003
    Montgomery, AL US
    If it was mine, I'd check on getting them all pinned at a machine shop. If you have some sort of press I suppose you could remove it yourself. It would just suck if another one did the same thing after a period of time.
  7. 79camaro2001
    4,759
    May 4, 2003
    Monroeville, PA
    If the heads are coming off, then take it to a machine shop, it's a easy job for them. Shouldn't cost much.
  8. 1979rallysport
    566
    Mar 18, 2009
    Bay City, Michigan
    called them up, they said $20-25, without a new stud i have to buy that.
  9. 79camaro2001
    4,759
    May 4, 2003
    Monroeville, PA
    stud is like $5 I think?
    I wouldn't chance it, cause considering how much load these studs are subjected to.
    I ran screw-in studs due to this reason.
  10. Simon@London
    1,244
    Feb 16, 2009
    London Ontario
    X2 and for 25 bucks.......can't beat that. Since you got one off take both heads and get them done while it's down.
