Anybody alive in OK???
Discussion in 'Oklahoma Region' started by gutted72, Mar 28, 2016.
  1. jeff swisher
    jeff swisher Veteran Member
    1,029
    262
    Apr 26, 2018
    Yukon Oklahoma
    Odd looking where do you mount the carburetor??
  2. bazookatooths
    bazookatooths New Member
    12
    Apr 25, 2018
    OKC OK
    If you want to go carb will have to spend a bit more but it can be done. I love the look of the LS intake which I can reuse cheaper oem parts. This is my first ever engine build and I am having the time of my life. I went with a junkyard 5.3 Vortec iron block due to cheap price and great performance.
  3. CamaroDoc
    CamaroDoc Veteran Member
    1,917
    68
    Sep 13, 2003
    Skiatook, Okla. 74070
    I think that is the first time I have ever heard the terms "LS" and "cheap price" in the same sentence... Good luck and happy building.
  4. bazookatooths
    12
    Apr 25, 2018
    OKC OK
    Yes cheap is definitely a relative term, but you can find these 4.8/5.3 complete for around $500 which ain't bad for 300-330 HP stock then I will literally add only a cam(stage 2) and be around 400 HP , I'd like to see you match that HP per $, you can't.
  5. gutted72
    gutted72 Veteran Member
    1,187
    56
    Mar 4, 2002
    Jennings, OK
    Well I finally went and did it this time o_O.
    I actually put some paint on the Camaro, well at least on the underside of the hood :rolleyes:.
  6. jeff swisher
    1,029
    262
    Apr 26, 2018
    Yukon Oklahoma
    Very shiny but I ordered flat black!!!
    Lets see how this plays out on cheap build.
    $150 used short block with good rings and flat tops melling oil pump.
    Old chevy truck 1978 ish $500 pulled engine radiator and transmission had roller cam in it and RPM air gap.
    Rebuilt 4 bolt 350 aluminum china heads new radiator multiple cores.
    Sold truck for $550.
    Cost 25 in gas to get it here.
    $25 ahead. More if I sell the stuff I do not need.
    $60 Regrind the roller cam to Hot cam specs but 110 LSA and exhaust lobe duration on both intake and exhaust.
    Gaskets $70 cam button Not much.
    25 each for complete vortec 906 heads with rocker covers and all and another 10 for crack warranty.
    IOU for screw in studs and guide plates labor.. would have been 80. Yea I spent 80 more flowing them after I ported them.. spent less than 20 porting them.
    OH yea Pac springs and retainers $190
    Yea you can do it on the cheap if you get crafty.
    Yes mine is adding up.
  7. gutted72
    1,187
    56
    Mar 4, 2002
    Jennings, OK
    Got off my butt and put some color on the top of the hood :cool:
    jeff swisher likes this.
  8. gutted72
    1,187
    56
    Mar 4, 2002
    Jennings, OK
    The easy stuff is done, now i have to work on the actual car :( IMG_20190514_171034297.jpg IMG_20190514_171043470.jpg
  9. gutted72
    1,187
    56
    Mar 4, 2002
    Jennings, OK
    Since i still had paint in the cup, i did the shifter plate also ;)
