Anybody have a brake booster laying around?
Discussion in 'Camaro Questions' started by Jeep43, Jul 11, 2019.
  1. Jeep43
    Jeep43 Veteran Member
    1,193
    41
    Mar 30, 1999
    Connecticut
    I need a measurement. I imagine it's the same for all 2nd gens. The flat of the bracket to the pushrod hole ID. 0711191943.jpg
  2. Twisted_Metal
    26,629
    763
    I've got two of them which look just like that.
    Unfortunately…. Neither of them worked worth a damn. :mad:
    The first one wouldn't let pressure back to the master and after trying to shim it to the correct position, it felt like I had manual brakes.
    The second one never felt right and then it developed a vacuum leak soon after installation.
    Two pretty parts but basically garbage... Just taking up space in my garage somewhere. :(
    (In other words... A measurement of my junk probably wouldn't be of any real help.)
    I still had the booster from my '78.
    I painted it, swapped it in and haven't had a problem with power brakes since then.
    I can't say that I can recommend these repops after the experience I had with them.
    Maybe it was a fluke that I got two bad ones but I felt no need to try a third one.
  3. Jeep43
    1,193
    41
    Mar 30, 1999
    Connecticut
    I'm looking for a measurement off an oem unit. The repop is coming off but the NOS reman I bought has a shorter rod.
  4. dale68z
    dale68z Veteran Member
    1,331
    15
    May 14, 2009
    Glendale Arizona
    I have 8 5/8 to the best of my measuring ability 71 camaro oe booster
  5. Jeep43
    1,193
    41
    Mar 30, 1999
    Connecticut
    Damn. The one I bought measures 7.5". It appears swapping pushrods requires booster disassembly......
  6. dale68z
    1,331
    15
    May 14, 2009
    Glendale Arizona
    I would cut and weld it back to correct length if it will not come out. Or try threading /running a die on your rod and buy a threaded clevis for the pedal.
  7. Lars_2Gen
    Lars_2Gen Veteran Member
    548
    124
    Dec 29, 2017
    Fullerton, CA
    I just replaced mine and still have the oe one in the garage. Will snap a pic after a bit.
  8. Lars_2Gen
    548
    124
    Dec 29, 2017
    Fullerton, CA
  9. Lars_2Gen
    548
    124
    Dec 29, 2017
    Fullerton, CA
    Looks like just over 9"
  10. Jeep43
    1,193
    41
    Mar 30, 1999
    Connecticut
    Thanks everybody. Apparently the one I got had the wrong pushrod installed for the P/N it was listed as. I'm going to look into cutting the rod and extending it with a steel sleeve.
