Anybody try the McLeod Musclecar 5 Speed?
Discussion in 'Transmission & Driveline Topics' started by Jeep43, Oct 7, 2019.
  1. Jeep43
    Jeep43 Veteran Member
    1,308
    48
    Mar 30, 1999
    Connecticut
    Looks interesting. Not sure of the reviews though? I've had a few TKO's and liked them but wanted some info on the McLeod.
  2. 76z28
    76z28 Veteran Member
    2,051
    51
    Jun 29, 2009
    bakersfield
    I do like the over drive option of I believe a .75 on that. I couldn't imagine a tko600 with a .63 it would be literally worthless in my car. The t56 magnum's .8 is ideal for me--so I imagine the .75 would be close.
  3. BonzoHansen
    19,444
    799
    Jun 1, 2005
    Scott from Hamilton, NJ
    why, what rear gear do you have?
  4. biker
    biker Veteran Member
    934
    97
    Dec 7, 2014
    New Liskeard Ontario Canada
    I thought the .63 OD in my TKO 600 might be too tall, but it actually works very well for what I do. I don't have a ton of power, maybe 475hp, but it allows me to pull past 135mph (gps) and keep climbing, which I would do if I had any confidence in my tires above that speed. And at cruising speeds, it will lope along nicely at 2300 rpm somewhere around 75mph. My tach and speedo are suspect but thats the ballpark that I remember from last cruise. I have 3.73 rear and stock size tires.
  5. 76z28
    2,051
    51
    Jun 29, 2009
    bakersfield
    3.73 with a set of 28.5 inch tall tires.
    Going to 4.30 next as I feel that'll be the best all around gear with this set up.
    I cant hit over drive until 70 due to my camshaft.
  6. BonzoHansen
    19,444
    799
    Jun 1, 2005
    That's a tall tire. My t56 and 390s are good, but 26" tires
  7. 76z28
    2,051
    51
    Jun 29, 2009
    bakersfield
    Honestly if I had 26 inch tall I'd probably be happy but 4.30s is ny next update
  8. flht99b
    flht99b Veteran Member
    282
    46
    Nov 28, 2014
    Knoxville, TN
    I run the TKO600, .64 5th gear, 4.10 gears and a 28" (235/70-15) rear tires. Tach and speedo calibrated though both are stock and original to my 71 Z28. Turns a touch over 2200rpm in 5th at 70mph. During this year's HRPT we spent a great deal of time on secondary roads at 55 to 65mph. Either a lot of rpm in 4th or lugging in 5th. Contemplating a change to a shorter rear tire.
  9. Jeep43
    1,308
    48
    Mar 30, 1999
    Connecticut
    LOL, I guess nobody with the McLeod musclecar 5?
  10. badazz81z28
    16,991
    522
    Las Vegas, NV
    I don’t know of anyone. I highly contemplated it years ago, but they failed to release it as promised.
