Anybody using ELECTRIC tankless hotwater heaters?
Discussion in 'The BS Topic' started by Fbird, Jun 9, 2019.
  1. Fbird
    3,699
    524
    Feb 12, 2011
    atlanta, ga
    I'm doing a bath reno...as well as a HALF house (currently) re-pipe (due to polybutylene). I will be feeding 2 full baths. My question/concern is should i install 1 3-4 gpm ELECTRIC tankless to run these 2 baths? or will a 6 gpm run the entire house? (maybe a pr of 4.5's?)
    3 1/2 bath house dishwasher, kitchen, washing machine?
    Any REAL WORLD experience here would be helpful. I have plenty of breakers left...(like my check book..lol)
  2. dave@ztech
    3,253
    654
    Mar 27, 2016
    NY
    I would think unless room is the concern there are much better ways to heat water then an ELECTRIC, tankless, we have only installed gas ones , and they make some sense, if room is an issue , as they can save some money , the electric ones are more efficient , however less in savings and can be a hit when they actuate as the are 100 AMPS 240 , if you have 3 phase maybe add a little more saving , over 3 - 30 amp breakers , you are , perhaps starting with a higher inlet water temp, so that helps , in NY the water is cold , Also there is some saving in plumbing as some will use a smaller one for a remote bathroom so they are not running a hot line across the entire house to safe on costs for heating water , that sometimes never makes it to the faucet before it is turned off HA HA , so I guess no real world help , just a bunch of questions, sorry!!
  3. sprink
    sprink Veteran Member
    485
    106
    Apr 27, 2008
    ffx, va
    Can't help, we don't install them.
    I do get mixed reviews from customers who have them.
    Talk to people who have them.
    Got to be sized correctly. They may supply endless hot water, but maybe not if more than x amount of faucets used at same time. Water savers or not in showerheads change gpm also.
    Good luck.
  4. Todd80Z28
    11,424
    191
    Jun 11, 2002
    Northern VA
    I've looked at these for two decades now, and the electric ones don't seem to deliver as promised. Plus savings has ended up nil or actually increased energy and water cost- they found those who have endless hot water tend to use endless hot water.
    If you are after energy ($) savings, you might look at heat pump water heaters. They also provide a slight AC effect in their installed location, since they pull heat from the air to heat the water- should be a net positive in the South, whether it's in your house or garage.
  5. danbrennan
    danbrennan Veteran Member Lifetime Gold Member
    3,437
    241
    Mar 13, 1999
    Brighton, MI
    I put a Steibel Eltron in the water feed for my wife's Japanese soaking tub. That kind of tub is supposed to be drained every time it gets used, and so when filling it from our natural gas 40 gallon hot water heater, she would have to turn off the tap 3 times, and wait 20 or 30 minutes for the water tank to get hot, before resuming filling.
    The Steibel did put an end to that - it supplies continuous hot water - but the flow seems a bit reduced. I thought the fittings were kind of small when I plumbed it in, not the 3/4" I would have expected. I asked a builder friend about it, he said that's a common complaint with at least the Steibels(he otherwise liked that brand), if not most on demand water heaters.
  6. serpent710
    serpent710 Veteran Member
    788
    34
    Jul 6, 2007
    Fort Lauderdale, Florida
    I have a Titan N-120 for a 3/2 house. Have not installed it yet but can let you know how it works.
  7. ZEN357
    ZEN357 Veteran Member
    373
    66
    Feb 12, 2018
    I have a friend who owns his own construction company. He is very reputable and knowledgable. He won't install them. He says to go with a traditional tank.
  8. tom3
    tom3 Veteran Member
    11,792
    295
    Aug 1, 1999
    ohio
    Son put in one, draws 50 amps at 240v when running. Won't supply one shower, even with a saver shower head, when the inlet water temp is 58 degrees. If you put in an electric heater make sure it's way over sized, maybe double the expected flow. Really not worth the expense for normal household use I think. What happens when the heat exchanger gets insulated by mineral build up inside the coils? No normal water supply is clean enough to prevent this that I know of.
  9. Canadian Barton
    Canadian Barton Veteran Member
    230
    43
    Jul 20, 2015
    Alberta
    I run a small electric unit (Rheem RTE 13, 4GPM) out in the garage. When I built it I wasn't really thinking and only ran a cold line. Hindsight I tell ya...
    It's perfect for washing up but I wouldn't use it for more than one faucet. That said our water is probably a few degrees colder in Western Canada than in GA. It works great in the summer however in the winter I can't open the faucet fully otherwise I get lukewarm water. Hope that helps.
  10. danbrennan
    3,437
    241
    Mar 13, 1999
    Brighton, MI
    Yes, when I bought it, it was strongly recommended I add a filter to the inlet side. That's the blue and white cylindrical thing hanging down from the lower copper run. It does have to be replaced periodically.
