Anyone able to extract broken bolts from heads?
Discussion in 'Engine Topic' started by SavingTheBird76, Feb 28, 2012.
  1. SavingTheBird76
    SavingTheBird76 Veteran Member
    313
    Dec 13, 2009
    Mentor,Ohio
    I have three running motors..all three need heads,one doesn't accept headers only expensive manifolds,one is a sludge monster,one has 2 broken exhaust studs...
    The $1500 crate motor is looking better each day.
    I just hate to scrap running engines...something is just not right here.
  2. gregs78cam
    gregs78cam Member
    51
    May 2, 2004
    Spirit Lake, ID
    Ways I have done it.....
    Grind off what ever you can/need to, to get a good flat surface. Center punch the bolt. Start with a 1/8" Left hand drill and drill completely through the remaining bolt. Soak inside and out with WD40, PB, even alcohol can work sometimes. Heating it can help sometimes too. Then, using a 5/16 Left hand dill bit, drill on LOW(for torque), spin it up and holding it good and straight, jam it hard to the bolt. A lot of times the instant torque and a good sharp drill will grab and turn it out. I have taken a lot of broken bolts/studs out that way. If not it is good and lubed up, Drill though with the 5/16 and peel out the remaining thread.
    With larger thread sizes, I have even used a cutting torch to heat the bolt untill it glows good and hot and just hit the OXY lever for split second and the bolt will just disappear, leaving the threads intact.
  3. Air_Adam
    Air_Adam Veteran Member
    2,927
    Feb 7, 2004
    Saskatoon, SK, Canada
    You're a brave man lol
  4. FatnLow
    1,953
    Mar 12, 2003
    Montgomery, AL US
    What type of bit works best on drilling out easy out. Man I had the stud drilled through and I should have just drilled the rest and retapped. This is on an aluminum head exhaust stud.
  5. Jimmy9294
    Jimmy9294 Member
    71
    Oct 14, 2012
    Aston Pa
    Before you drill it file the top flat so that when you punch it your right in the center, if your off to the side it makes it hard with an easy out.
  6. markw
    markw Veteran Member
    818
    Jun 6, 2009
    Illinois
    You're not going to drill out an easy-out. They are very hard (which makes them very brittle and prone to snapping off). If you have a steady hand you could try a Dremel tool with a carbide bit to grind it out but you could very easily ruin the threads. It might be time to cut your losses and pull the head and take it to a pro. At the very minimum you need a Bridgeport mill and a carbide bit. A good shop will have an EDM machine to burn it out.
  7. FatnLow
    1,953
    Mar 12, 2003
    Montgomery, AL US
    The head is off. I plan to take it to a pro tomorrow. Thanks.
  8. MyBoTy
    MyBoTy Veteran Member
    1,567
    9
    Feb 9, 2002
    Lubbock, Texas USA
    ^ good plan, all the described procedures are much easier to do with the head fastened in place and using a drill press instead of trying to hand-drill straight.
