Anyone have pics of there motor mounts with engine out??
Discussion in 'High Tech Retrofits' started by QUAKE_WARS, Aug 17, 2016.
  1. QUAKE_WARS
    QUAKE_WARS Veteran Member
    1,969
    120
    Dec 19, 2008
    here you can see how high the motor sticks up. Not good pics.
    1 more of the engine hitting A/C box
  2. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    well, looks like you won't be running AC :D
  3. QUAKE_WARS
    1,969
    120
    Dec 19, 2008
    Lol, I'll get rid of all the holley stuff before that happens.
  4. 71RS/SS396
    71RS/SS396 Veteran Member
    2,624
    27
    Aug 26, 2008
    Wake Forest NC
    Have you checked your engine angle? It should be 3*-3.5* down in the rear, maybe it's just the pics but it looks like the engine is low in the back. I would mock-up the trans and crossmember to see where you're at before I made any hasty decisions.
  5. badazz81z28
    16,375
    406
    Las Vegas, NV
    I saw the potential AC clearence issues before I did my swap, that's why I pulled the box out on both my swaps. The LS seems to be a wider engine. I also had problems when I did a BBC
  6. Dioskouori
    Dioskouori Member
    58
    Aug 5, 2016
    Deloit, IA
    You don't have the Trans hooked up do you? The photos of the motor mounts show it is tilted down at the back quite noticeably so your angle is off. If you have a magnetic angle finder, put a two by four on a jack and lift the back of the engine up to that -3 to 3.5 degrees 71 mentioned and see how that affects anything.
  7. DMurda
    DMurda New Member
    11
    Aug 22, 2016
    Clarksville, TN
    So funny story, those mounts can't be configured in two ways, and the instructions actually give you the incorrect way to mount them. Got my ls3 on to those mounts scratching my head at 2 am trying to figure out why it wasn't sitting on the mounts right. Little Google action and few curse words later and I was set.
  8. LT1 WS6
    LT1 WS6 Veteran Member
    510
    May 25, 2009
    Sandy Springs, GA
    Care to post the correct way to install the mounts, DMurda?
    Quake, I highly recommend stripping an engine of unnecessary components, accessory components/brackets exhaust manifold etc, before trying to install it for the first time. This is especially true if you're unsure of a component fitting like the accessories or exhaust manifolds. It makes an engine easier to position if there's less weight and less possibility of snagging on a component. Good luck getting everything in.
  9. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    I didn't get the sense that the Holley LS engine mounts installed more than one way.
    From their instructions:
  10. QUAKE_WARS
    1,969
    120
    Dec 19, 2008
    Your right. They only work 1 way. Almost no way to put them on incorrectly.. I got my dirty dingos in. Will post pics later.
