Anyone here install tweeters in your door panels? Post pics.
Discussion in 'High Tech Retrofits' started by slayer021175666, Apr 25, 2018.
  1. slayer021175666
    slayer021175666 Veteran Member
    1,217
    60
    Feb 29, 2016
    Idaho
    Thinking of putting 6.5 components in my doors and having the tweets mounted above them in the doors as well. Have any of you guys done this? Have any advice? Pics would be great!
    Thanks.
  2. slayer021175666
    1,217
    60
    Feb 29, 2016
    Idaho
    Nobody?
  3. Twisted_Metal
    27,057
    996
    I put tweeters at the top of the "A" pillar.
    (I wasn't about to chop into the factory deluxe cloth door panels.)
    I'll try to remember to take a pic of the speakers this evening.
    Here's a diagram showing where they are directed:
    You don't want them pointed straight at your head (or the passenger) because high frequencies are very directional and tend to be a bit harsh at higher volume.
    If you're interested in the whole system layout....
  4. slayer021175666
    1,217
    60
    Feb 29, 2016
    Idaho
    Thanks Terry.
    Where did you put your crossovers?
    Jess
  5. slayer021175666
    1,217
    60
    Feb 29, 2016
    Idaho
    I just installed the brand new standard door panels and I was very conflicted about cutting them for speakers. I need tunes though and I'm dead set on the 6.5s going in the doors. The door metal itself is already cut for speakers but, any suggestions on a good way to cut the vinyl and cardboard of the panels? I was thinking maybe a razor knife for the vinyl and foam and then, a jig saw or router for the cardboard. ???
  6. Twisted_Metal
    27,057
    996
    Crossovers are under the console.
  7. slayer021175666
    1,217
    60
    Feb 29, 2016
    Idaho
    Great place for them!
  8. Blown Camaro
    Blown Camaro American by birth, drag racer by choice
    1,199
    140
    Dec 13, 2009
    Deltona, FL
    I put adjustable tweeters in my Custom Deluxe door panels. Because I have power windows, I had a manual crank hole to fill. Guess what filled the hole perfectly? :D
  9. Twisted_Metal
    27,057
    996
    This is where I mounted the tweeters. The wire runs down behind the pillar cover.
  10. hoppin5478
    581
    98
    Jul 20, 2015
    Tucson, AZ
    Here is a picture of the custom panels I made. You could always put a custom box over the door panel, similar to mine so you didn't have to cut a hole. You would however still have to put screw holes through it though. I was going to originally put the tweeters in the same box with the 6.5's but opted to put them on the pillar. A little fleece and fiberglass and you can make about any style pod you like. I wrapped mine in vinyl to match the interior.
    75Maro likes this.
