Anyone install a double DIN in a 2nd gen?
Discussion in 'Car Audio, Electronics & Security' started by MrTailLight, Feb 7, 2013.
  1. XxWickedz28xX
    XxWickedz28xX Veteran Member Lifetime Gold Member
    5,980
    May 22, 2001
    Carmel, NY
    This looked good. I just wonder what he did with the original radio spot. I'm anal about everything "flowing" interior wise, besides another set of gauges what could possibly fill that spot?
    And holy cow that is the TALLEST shifter I've seen in a 2nd gen.
  2. Batjac
    Batjac Veteran Member
    176
    Jul 24, 2005
    Portland, OR,USA
    Strange, I've always preferred the 79-81 dash. The curved dash always seemed to waste so much real estate. I can see the "boxy" dash space as easier and more pleasing to the eye to use for modifications/additions.
    But that's just me.
  3. 1979CamaroTX
    1979CamaroTX Veteran Member
    178
    Oct 10, 2006
    Longview, TX
    I plan to do my stereo install like this and move the AC vents down to the factory radio location.
  4. FunBobby
    FunBobby Veteran Member Lifetime Gold Member
    647
    12
    Feb 28, 2012
    Simpsonville, SC
    Double Din in 79-81 Dash Bezel
    Just wondering if anyone else has done this and can share do's and don'ts - +1 on the plan to put a double din where the AC vents are, and Install an AC vent at the stock radio position. I've been researching the double Din "cages" - I guess I'll pick up a double Din cage and trim ring and figure it out.
  5. chevy2ss
    chevy2ss Member
    89
    Jul 11, 2012
    Poconos, PA
    i just did this. was a pain in the butt but i think it will be worth it.(cars not driveable yet).
    the way i did it was i took 1/8 inch by 2 inch steel that they sell at lowes and made my own cage to surround the radio leaving a 1.5 inch or so gap on the back side. drilled and slotted the backside so i could put a mounting bolt thru it(and allow adustment to center it in the hole and bezel i made) i then came down from another bracket that i placed under the front speaker grill (i didnt weld this in i bolted it using 3 button head bolts thru the speaker grill) i made and bolted the two together ,got it centered and tightened the locknut. boom done. it did take 4 hands to get it positioned and then tighten it down. best pic i have right now
    Zstar likes this.
  6. ATM
    ATM Veteran Member Lifetime Gold Member
    2,265
    Oct 10, 2009
    Morris, Illinois
    I've got the aluminum gauge panel, and this is what I am going to do.
  7. FunBobby
    647
    12
    Feb 28, 2012
    Simpsonville, SC
    Thanks for the description - I think I follow what you did - that's the part I've been thinking about - I hadn't really thought about making it adjustable, but I knew the challenge would be getting the cage exactly lined up - adjustable is probably the way to go!
  8. rh80camaro
    rh80camaro New Member
    May 7, 2012
    morganton, nc
  9. rh80camaro
    May 7, 2012
    morganton, nc
    so really how hard is it and what did you do with ac vents. I am about to install double din in my 60 camaro
  10. 1971CamaroGuy
    3,763
    161
    Oct 31, 2004
    Seen this on Facebook the other day, not sure how they did it...but at first glance looks like they built some sort of pod. I know they cut the lower dash up...cut the hole area below the radio opening out. 24232394_540739879610114_2868425230577712275_n.jpg
