Anyone replaced their spare with a donut?
Discussion in 'Camaro Questions' started by Millwright, May 12, 2019.
  1. xten
    xten Veteran Member
    2,451
    1,239
    Sep 24, 2014
    Pittsburgh, Pa.
    My collector car insurance has towing and road service. Also a AAA member. Two spares! AAA is cheaper for the whole year than one tire, and covers all my cars.
    hubedobeedo likes this.
  2. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,336
    77
    Feb 2, 2008
    SF
    I agree if you can deal with waiting an hour or two to get towed
  3. Millwright
    Millwright Member
    49
    22
    Mar 30, 2019
    Ontario Canada
    I have roadside assistance through my insurance and 1 credit card. I am going to try to pick up a space saver so I have something with me. The full size is too big. Local scrap yards said $20-$25 if I can find one there. pretty cheap.
  4. $ Mike 70 Z-28
    $ Mike 70 Z-28 Veteran Member
    950
    16
    Nov 7, 2002
    New York, NY
    Twisted.. when you say close to size . How close???
  5. Twisted_Metal
    26,629
    763
    The closer the better.
    Any variation in overall diameter forces the Posi clutches to slip while driving straight.
    The greater the difference, the more slippage which builds heat in the rear end and wear on the clutches.
    You could get by with an inch difference at low speed for a few miles but a cross-country trip at freeway speed would be the equivalent of driving in a circle for hours.
    The diameter difference, speed and length of time of continuous slippage all plays a role in what it will tolerate.
  6. Gary S
    22,018
    624
    If you have posi, put the spare on the front when needed and put two like tires on the rear. That is the #1 reason you want to run the same size tires on all 4 corners on a car.
    BonzoHansen and tom3 like this.
  7. Millwright
    Millwright Member
    49
    22
    Mar 30, 2019
    Ontario Canada
    That is a good solution. A bit more work but reduces the risk of damaging the rear end.
  8. serpent710
    serpent710 Veteran Member
    781
    33
    Jul 6, 2007
    Fort Lauderdale, Florida
    Anyone know the exact car or truck to use?
  9. Gary S
    22,018
    624
    It depends on the size tires you currently have on the car. Like Twisted said, look for one of similar size.
  10. xten
    xten Veteran Member
    2,451
    1,239
    Sep 24, 2014
    Pittsburgh, Pa.
    If the plan is to keep a space saver spare, I wouldn't worry about it being older. UV is a major factor in deterioration, and most spares rarely see the light of day. Also, if like some, you run staggered aspect ratios (bigger rear than front), I would match the height of the rear tire as close as possible so you could use it on front or rear. Hopefully you won't be driving far on it.
